Question about Broderbund Computers & Internet
I have Broderbund's Calendar Creator, Version 8.0. I recently went into the program to print off a blank copy of the April 2011 calendar. When I clicked on the 'Print' button, a box came up in the middle of my computer screen that said: "Program has not found current paper stock among stocks supported by your printer. Here is a list of supported paper stocks." [No paper stock is listed] and then it says: Program will use default paper stock." Then there is a little box where I could click 'OK', but it does nothing when I click on it. Help!
  • 25 Answers
SOURCE: Microsoft Works Calendar.
I hope you can do a quick update using windows setup CDs or windows update from your browser if you are connected to the internet. Mostly this should solve the issue. If not mail me.
Posted on Jun 07, 2008
Basti
  • 1447 Answers
SOURCE: Won't print a 4 x 6 print. Paper passes right through printer
Hi-
Double check on printer properties under printers and faxes if 4X6 is selected, then access printer properties as well on the application or program where you are printing the images by clicking File then print option. Make sure Epson is the default printer.
Keep us posted, thanks!
Posted on Oct 29, 2008
SAKTOM7
  • 3 Answers
SOURCE: Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Posted on Nov 04, 2008
  • 35 Answers
SOURCE: How do I print to tab paper on Canon imageRUNNER C3220
Tab stock is not supported on this model. See the Media Guide.
http://opd.usa.canon.com/html/consumables/pdf/consum_iR_CiR_CLC_iP.pdf
Posted on Nov 09, 2008
  • 20 Answers
SOURCE: Anytime Organizer Problems
You could try using 'map network drive' to create a drive letter reference for your network file location. I don't know what operating system you're using, but you should be able to find this option in Windows Explorer.
Select a drive letter that you're not likely to use for anything else (such as X), and enter the path to the file you're trying to use.
( //<your server>/.../ ).
Once this is done you can refer to the file as X:/<your file name> instead of //<your server>/../<your file name>
I hope this helps, let me know if you need any more detail on this!
Posted on Mar 14, 2009
How to change the line spacing within text boxes?
As far as I can tell ther is no way to change the line spacing on the Calender Creator Delux edition. However, there is a work around. You can find out how here: Margins Line Spacing.
Hope this helps!
Sep 13, 2014 | Broderbund Calendar Creator 12 for PC
Calendar creator deluxe windows 8
Calendar Creator is not supported for Windows 8 at this time. Even the newest version which is 12 is not supported fo Windows 8. You could try running it in compatability mode however.
Right click the Icon and select "troubleshoot compatability"
Hope this helps!
Jan 19, 2014 | Broderbund Calendar Creator Deluxe 10 Full...
I can't get calendar creator version 8 to print
Calendar creator is proprietary, i.e., it only recognizes paper stock, size, finish, etc., in it's catalog. If your printer isn't set up correctly, CC throws an error...
Oct 02, 2012 | Broderbund Calendar Creator 8 Full Version...
How to remove calendar creator 12 from Windows Vista
  • The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
    1. Start-->Control Panel-->Add/Remove Programs.
    2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
    3. Follow the panel wizard and reboot your PC when it finished.
    In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
    Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
    A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
    1. Free download Perfect Uninstaller form its official website.
    2. Install Perfect Uninstaller on your computer
    3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
    4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
    It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
    Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
    Under Creative Commons License: Attribution
  • Feb 03, 2011 | Broderbund Calendar Creator 12 for PC
    I can't get Calendar Creator 12.1 to run on my windows 7 64-bit system
    Windows 7 Compatibility for Broderbund Calendar Creator version 12 :
    32-bit(compatible) and 64-bit(We are working with the software publisher to confirm this product's compatibility) -->click HERE! to navigate .
    Run the program in compatibility mode:
    1.Right click on the program's shortcut, .exe file, or installation program;
    2.Click on Properties.
    3. Click on the Compatibility tab. (see screenshot below)
    NOTE: If the Compatiblity options are grayed out, then it is a 64 bit program and cannot be changed.
    OR..
    You can use windows xp mode to run calendar creator .
    Please navigate to this page click HERE! and follow microsoft instructions ..
    Please let me know if you need any further assistance.
    Dec 29, 2010 | Broderbund Calendar Creator 12 for PC
    I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
    Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
    - File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
    -For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
    -For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
    - Save your changes by clicking OK and Ok again. Make changes for all for events.
    - Select File and Save Collection
    - You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
    I hope this gets you what you need.
    Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
    Will Calendar Creator 12 work with Windows 7 64-bit OS?
    Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
    Jan 19, 2010 | Broderbund Calendar Creator 12 for PC
    Am trying to install Broderbund Calendar Creator Deluxe 12 on my HP pavilion lap running Windows XP. Problem is first disk tells me an older version of Calendar Creator must be removed before ver. 12 can...
    Usually in this situation when you loadup the new version it usually says what you are saying then goes on to ask if you want it uninstalled, you click yes, it then removes, you then usually restart and new version kicks in?
    Reload new version see if it gives the chance to remove before it installs. It has to be removed as you are aware. ?
    Nov 14, 2009 | Computers & Internet
    Unable to uninstall calendar creator 10 from vista
    RESTORE UR CPU IN SYSTEM RESTORE TO A DATE BEFORE YOU INSTALLED IT
    May 15, 2009 | Broderbund Calendar Creator 10 Full...
    Computers & Internet Logo
    291 people viewed this question
    Top Broderbund Computers & Internet Experts
    Alun Cox
    Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
