I have a sharp er 3220 cash register making a beeping sound,keys are locked and has all 0000's,found broken ribbon take up spool drive belt,replaced it but still have code...HELP!!!
  • 3 Answers
SOURCE: SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Posted on Jan 26, 2008
  • 298 Answers
SOURCE: ER-A330 SHARP CASH REGISTER PROGRAMMING MANUAL
The original English Manual has been discontinued. The only manual available is the German Version located here.
Posted on Mar 25, 2008
I hope you did not reset the machine in the aformentioned method. If you have a service key there is a way to clear the totals but not like a Samsung. It involves z1 z2 and some 900 codes.
Posted on Nov 20, 2008
  • 159 Answers
SOURCE: Sharp er-a330 cash register prob'
The Sharp ER-A330 and ER-A310 both have a calculator function that turned out to be just trouble for users who don't need it and don't know how to turn it off. At the bottom-left of the keyboard is a button labeled PO. Normally you enter a dollar amount and touch that to Pay Out money from the till. On these models it also activates the calculator mode, allowing you to add and subtract numbers without affecting sales.Touch PO to turn calculator mode back off, and you'll have a cash register again.
Let me know if this isn't the fix you need.
Posted on Dec 24, 2009
flexion1
  • 737 Answers
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it. ------------------------------------------------------------------------
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
Posted on Mar 28, 2010
Sharp ER A180 don't work only makes beep beep
Your key on Reg press 1 then #/cash key(Blue key on topmost right)
Apr 28, 2015 | Retail Supplies
Cash register has been locked
Check you keyboard if there isn't any key that is stuck down
Nov 26, 2013 | Sharp Retail Supplies
Samsung er-5115 sam4s cash register is locked up and read PP00. Unplugging does not do anything. None of the keys respond.
Your printer is stuck.1 open the printer cover 2Pull out he ribbon 3 plug your machine, that should work
Sep 18, 2013 | Sam4s Samsung Er-5115ii Cash Re
Sharp cash register (er-a470) won't turn on.
Hi. You may have a bad battery. This can cause lock ups. If it hasn't been replaced in the last 3 to 4 years, take it to a dealer to have the internal battery replaced. The battery will eventually leak all over the inside of the machine and damage it beyond repair. --------------------------------------------------------------------------------------------------
I've had many requests for the Sharp ER-A470 manual. Here is a link http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
May 14, 2010 | Casio Parts Cash Register PC Desktop
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
Mar 24, 2010 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
