Question about Kenmore Side by Side Refrigerator
I have installed a new icemaker and it is not working, where do I need to turn it on? or what should I do?
    Problem Solver:
  • 10 Answers
Kindly Refer the user manual that you get when you purchase the Appliance of call an Appliance Repair Expert to fix the problem.
Posted on Mar 25, 2011
  • bpratt102 Mar 25, 2011
    This answer was no help, your website led me to believe this service was FREE but since I didn't pay anything I received no help. This site is a ripoff.
  • pioner
    pioner Mar 25, 2011
    Kindly If you notice I just give you an advice which mean to refer the manual . Dear If you try to fix the problem yourself it will just increase your problem as you are not expert. There will be also huge danger of electric shock all the time. So I suggest you to call a repair expert so you can get benefit from his experience. It may cost some dollars but life is more precious
Installed new icemaker still not making ice
Some icemakers have to be turned on inside the Freezer at the Icemaker itself, it might be as simple as a small on/off switch or a lever that completes the curcuit to the solenoid that allows the tray to fill. Remember: None of that will matter if the Ice Tray "Overfull" Safety Bar is in the Up position because that is a Safety switch that shuts OFF Power to the Icemaker. For You Novices... That's the bent silver Wire rod thingy that hangs over the Ice Bin/bucket deal. Simply grasp it and see if it will move down a bit, gently. If it moves freely, downward, You should hear the Icemaker start working! WARNING: Don't use the first few batches of Ice, after the second or third cycle, it should be pretty clean.
Sep 26, 2014 | Kenmore Side by Side Refrigerator
Icemaker 106 626133 in 1987 Whirlpool ED22MMXRW sid-by-side
Happy to report that I now have a working icemaker. I had to replace the control module--just replacing the gear was not sufficient. The wiring was slightly different for the new module because it had a side connector instead of one coming out of the lower left corner, but I was able to use front metal plate plus its attachments (motors and switches) of the new to replace the similar parts on the old.
Jul 16, 2012 | Whirlpool Refrigerators
The water dispenser the ice dispenser etc one the left door is not be working that whole unit seems to be dead.
Highly unlikely both valves failed at same time. Not sureon your fridge but on some, if freezer door switch is not working, dispenserwon't work. Does the freezer light go off & on when door is opened &closed? If you have a voltmeter, check that water valve is getting 120 voltswhen dispenser is pushed in. If no voltage, I would suspect the micro-switchthat you hear clicking when you push in with a glass. Even though it clicks,the contacts could still be bad in it. If the icemaker is not gettingwater, check for the following problems:
  • Be sure that the icemaker is turned on and plugged in. The power cord for your icemaker is plugged into the left or back wall of the freezer.
  • Check to make sure that the water supply line valve is turned on. This valve is usually found under the sink or in the basement. This is the only water supply line needed for the refrigerator.
  • Be sure that the freezer has cooled down properly after the initial installation. This may take several hours.
  • Make sure the plastic fill line on the icemaker has not come out of the back of the icemaker.
  • Check the fill tube (plastic tube above the icemaker) going into the icemaker. In order to do this, the icemaker must be removed. If the tube is frozen solid, you will most likely need a new water valve.
If the ice-maker is getting water, but there is no water tothe dispenser, check for the following:
  • If the doors were removed during installation, be sure that the door wiring harness is plugged in. Refer to your Owner's Manual/Installation Instructions for the specific location of the wiring harness.
  • Check the water lines and make sure they are not kinked or restricted.
  • There is a tank behind the vegetable drawers or on the left side of the Fresh Food compartment that could be frozen. You may be getting water in the ice-maker, but not the dispenser. To rid the tank of the ice, check the set temperature on your controls. If it is set colder than the recommended setting, adjust to a warmer setting.
Hope this will help you. Good Luck.
Jul 20, 2011 | GE Profile PSI23NCR Side by Side...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker not working
it is hard to know what did happend to your unit but it can be check , and there is an arm that also turn the unit on or off but if you need to get new one the # is WR30X10061 for your unit and it is 120-160$
Dec 30, 2009 | GE GSS25LGM Side by Side Refrigerator
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
Nov 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Whirlpool side by side refrigerator with a new ice maker. The ice maker works fine but will not drop the ice. If I cycle the arm off/on (up/down) then it dumps the ice a few minutes later. ...
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. mca0824@aol.com
May 02, 2008 | Refrigerators
No ice on new ge profile fridge.fridge is 6mo old.several days ago service tech installed new ice maker.3 days later still no ice.filter has been changed
Hi dbalaban,
Only a few things that would cause this problem. So lets start with the easy one. It is possible the tech forgot to turn the icemaker on. If the icemaker has a metal arm just push it down to turn it on. Most GE model icemakers have a little toggle switch on the front of them, Just flip that puppy to on and viola.
The second thing would be the refrigerator is not getting cold enough for the icemaker to cycle. The best test for this is a thermometer. To function properly the freezer needs to get to 0 degrees or colder. If you dont have a thermometer then check your ice cream. If it is soft then you have a refrigerator problem and not a icemaker problem.
3rd possibility. This is probably easier than the first. The tech installed the icemaker and forgot to turn the water on.
I hope one of these fixes the problem so you will give me a FIXYA. I am glad to help. mca0824
May 01, 2008 | Refrigerators
Kenmore Side by Side Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
