To my surprise my Acer laptop has two 30G HD. I now get a low memory warning but my 2nd drive has pleny of space. How do I share files or link the 2 drives so i don't have a memory issue?
    Sergeant:
  • 395 Answers
I suspect you have one hard drive with two partitions C: and D: (??).
Download Sequoiaview from www.win.tue.nl/sequoiaview/
This will let you see what is taking up so much space on the C: drive. Then Move the files over to D:.
You don't say what OS you have (XP or Vista) so I cannot tell you how to re-map your My documents folder to the D: drive but usually you click the My Documents (or Document for Vista) link and then change the location to an existing folder on the D: volume. Then move all your folders in C: My Documents over to D:\My Documents.
Posted on Aug 03, 2008
How to solve low disk space warning on my Windows 7 laptop?
It sounds like you have too much running in the start menu. If you go there you have to be careful what you stop from loading. Go to your start and left click. The search box at the bottom type msconfig Go to the startup tab. Anything like Adobe reader, Java, any toolbars, quicktime, realplayer or anything that doesn't need to start when you boot the computer uncheck the box on the left beside it. When you click apply and ok it will ask you to restart the computer. After you do a box will popup and you can check the box and click and you won't see it again. But like I said you can stop the wrong things there. If you don't feel comfortable trying it get someone you know who is tech savvy to help you. Anything Microsoft, Intel, or with your computer brand name needs to stay.
Dec 10, 2014 | Toshiba Computers & Internet
E-recovery stalls at about 40%
Sounds like a problem with your hard drive. The original hard drive installed is 40Gb. The message "destination: \\harddisk0\partition2" indicates that your single HD has been set to 2 partitions. Chances are that the recovery files are saved in your 2nd partition D. If your laptop came with a recovery CD, try using that instead of the eRecovery ALT/F10. Alternately, you may want to use an OEM XP Home Edition Installer and choose the 2nd "Repair" option.
If things don't work out, you may need to re-partition the HD and reinstall fresh/clean. Of course this would erase any and all contents of the drive. Should there be important files, you need to back them up but that would mean removing the HD and using an external enclosure, connect it as a removable storage to a 2nd PC using the USB and proceed to copy all your important files assuming of course that the 2nd PC will be able to read the HD in question.
If even on the 2nd PC you are having difficulty accessing the laptop's HD, try running utilities (ScanDisk) to check the HD's integrity. Possible problems are bad sectors, missing partition, corrupt files and the likes. If there are bad sectors, you may need to purchase a replacement.
Hope that this be of some help/idea. pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Acer Aspire 3624WXCi Notebook
Clean up disk space window 7, already deleted unwanted items
If you run Disc Cleanup, in accessories, that will give the option to remove temporary and hidden files.
Sep 28, 2014 | Computers & Internet
Low memory
you must remove software ( go control panel and uninstall software that you are NOT using).
2) disk cleanup go to my computer click the icon properties, and go tab general.
3) cleant the browser from cooki,es and cache memory, in tab tools.
God bless you
Jul 28, 2013 | Acer Computers & Internet
LOW MEMORY
Hi Yeyek0905,
Good day!
I understand that your computer is running on Low memory.
If you have budget, it would be best to upgrade your RAM but then you may try the following solutions below:
For Low Virtual memory on Windows XP:
1. Click Start, then open the Control Panel.
2. Select Performance and Maintenance, and then click System.
3. Click the Advanced tab.
4. Under Performance, choose Settings.
5. Click the Advanced tab.
6. Under Virtual memory, click Change.
7. Under Drive [Volume Label], click the drive that contains the paging file (virtual memory) settings that you want to change. In almost every case, this will be your C: drive.
8. Click to select the "System managed size" option, then click Set.
9. Click OK three times and restart your computer
For Low Virtual memory on Windows Vista and windows 7:
1. Click Start, then open the Control Panel then select on Systems.
2. Click on advanced tab and select on settings for the performance option.
2. Select o the advanced tab then check on Virtual Memory(Change).
Uncheck the "Automatically manage paging file size", and select 'Custom Size'.
Increased the size based on the Recommended levels+200mb
You may also do the following to free up some space:
1. Delete Temporary files
a. Click on start and type in %temp% on the run option.
b. Delete all your temporary files.
2. Do a disk clean up.
a. Click on Start
b. Accessories
c. System tools
d. Select on disk clean up.
I hope this helps.
Best regards,
Jheycie
Jan 02, 2011 | Computers & Internet
How increase memory capasity?
yes With the help of partition magic you can increase the size of c drive without losing any data.
You can also install programs in d drive so that the low disk space will be avoided.
you can download partition magic from the link http://www.4shared.com/file/19023943/92099487/Partition_Magic_82_Full.html?s=1
Mar 02, 2010 | Acer ASPIRE 3680-2022 Notebook
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
HDD PROBLEM
HI,
The first thing is to do a disk cleanup.Go to START>PRROGRAMS>ACESORIES>SYSTEM TOOLS>DISK CLEANUP. Make sure you also clean all the system restore files.If you've taken a backup of your PC and you want to keep it then just ignore that part or else just go to the more options tab and select clean up under the system restore option in the disk cleanup.
If this doesnot fix the problem then:
there is a temporary file somewhere inside in the c-drive which is growing and eating up all your space. CLICK HERE to download the jam software.The run a scan with it it will tell which file is taking more space.Then just brows that file and delete it.
Goodluck..
May 08, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
