HP Color LaserJet 2600n - error message: Bitdepth and/or color space not supported by threshold set! Fatal Error! when trying to print PDF file. This is the first ttime it's given me trouble over PDF files.
Mrvica
  • 167 Answers
SOURCE: Print Problem in 2600n and Laserjet 1000
Just install 2600n manually and define as USB Virtual printer port!!!
Posted on Jan 24, 2008
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 237 Answers
SOURCE: Sensor error, turn off then on
Check the level of your toner or TOP errors. If the problem persists, let me know
Posted on Nov 25, 2008
SOURCE: Network Printer Problem
In the later HP LaserJet printers the printer has a "Mopier mode" that will provide better print performance on multiple copies. However, if you have "Mopier mode" enabled and you don't have an EIO hard disk installed, you'll get the above message.
Right click on the printer, select "Properties". There should be a "Device Settings" tab. Under that tab, make sure that "Mopier mode" is Disabled at the bottom.
The unit will still print multiple collated copies with that disabled.
Posted on Jan 21, 2009
SOURCE: ''Page too complex'' message on HP color laserjet 2840 Multifunct.
On the printer, hit the menu button
Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
then use the right arrow to navigate to high speed usb and hit enter.
it should now show on, use the right arrow once to change it to off and hit enter 2 times
let the printer reboot and its should be fixed
Posted on Mar 10, 2009
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Our HP Color LaserJet printer has a 10.10000 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0001 = Cyan print cartridge
try this:
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the cartridge.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
Network printer problem
try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Feb 04, 2010 | HP Color LaserJet 2600n Printer
No color on the laserJet 2600n
On the control panel (PRINTER) , Print settinGS, there must be a option to activate/desactivate print without color, only using black cartridge, you should desactivate this option and the printer will print on color.
If you couldn´t locate this option, restore the original settings on the control panel (printer) the error must be resoloved!
sorry for my english!
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Error Message 55.1. Turn off then on but this didn't help.
If you have a network card and optional memory...remove these items and try again.
Jun 09, 2009 | HP Color LaserJet 2600n Printer
Printer is not working
try to unplug the printer from the wall and plug it back in.let me know how this works
Feb 13, 2009 | HP Color LaserJet 2600n Printer
Printing Problem
You can print the Coniguration page and demos?
If so, somehow you may the settings to the printer wrong.
If you select , file, then print, see that the proper printer is selected.
If you can print those other pages, the printer and connection is fine. There is some setting not sending the print job from the applications.
Really sounds like the printer has be deselected at the default printer
Dec 07, 2007 | HP Color LaserJet 2600n Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
397 people viewed this question
k24674
jasbo
jasbo
