Question about Conair Nostalgic Telephones - 1950's Metropolis Wall Telephone
Cant get a dial tone - Conair Nostalgic Telephones - 1950's Metropolis Wall Telephone
We have a panasoic kx-tge433, when we receive a call and they need us to push a number to verify an appointment, etc we cant. Can you help me figure out what i need to do
Change dial mode to TONE !
Dialing mode If you cannot make calls, change this setting according to your telephone line service. The default setting is "Tone". "Tone": For tone dial service. DO NOT set to "Pulse":
[MENU]#120
Select the desired setting. which is
tone
page 15 of
ftp://ftp.panasonic.com/telephone/om/kx-tge432_en_om.pdf
Apr 27, 2018 | Lands Phones
I cant get a dial tone to call out says line in use but I have checked and unplugged all 4 lines still no dial tone everything else is good no dial tone
Try:
Turn off power for the base.
Turn off phone and take out batteries.
Wait few seconds then put batteries back.
Will help if you unplug and plug the cables.
Jul 14, 2015 | Lands Phones
Gigaset AL110 REGISTERED , CANT DIAL OUT OR IN
Is there a dial tone? And have you tried another phone? If there is a dial tone make sure the phone is set for tone dialing. There will either be a switch on the side of phone for pulse or tone, set for tone. or go into the menu and look for it there...
Apr 14, 2014 | Lands Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
No dial tone ,gets incoming, but cant hear anything, they cant hear me
Generic answer
You MUST get dial tone to talk or listen. Your base may ring but this may be unrelated to the telephone signal.
Check all wires and all settings. Are yoju certain your hand set is a member of your telephone group?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Dial tone
try this site for your solution.http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_alp.php?p_new_search=1&p_search_text=dial+tone&prod_lvl1=30&prod_lvl2=2627&prod_lvl3=669&prod_lvl4=80&p_pv=&p_pv=4.80&p_country_code=CA&p_reference=moto_integration.php
Oct 23, 2008 | Motorola Mobility RAZR V3
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Conair Nostalgic Telephones - 1950's Metropolis Wall Telephone Logo
Top Conair Lands Phones Experts
k24674
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
