Question about Minuteman C46000-00 Self Contained Carpet Extractor Vacuum
Belts for ambassador and ambassador junior - Minuteman C46000-00 Self Contained Carpet Extractor Vacuum
My electrolux ambassador power head goes on and off as I try to sweep. What can I do?
Most probably the hose has gone bad. You would new a new one. this will fit your vacuum
http://www.ezvacuum.com/electrolux-hose-with-switch-control-for-electrolux-canister-vacuum-vnotch-generic-p-1525.html
Jan 11, 2013 | Electrolux Vacuums
Looking for part number 831238 1/6hp brush motor
Try these people:
http://www.michco.com/p-102421-minuteman-ambassador.aspx
1- 800-331-3339
CustServe@Michco.com
831238-2
Item On Page-7-8 Ref# 128
Qty Required-1
This item replaces part#(s): 831238
Apr 16, 2010 | Minuteman C46000-00 Self Contained Carpet...
How do I dismantle an Electrolux Ambassador II?
you don't, as a repairman, even i have a hard time opening them, and then the hardest part is putting it back together.
Sep 14, 2009 | Vacuums
Hi, I have an electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the electrolux stop (has happened before) and when I pressed the reset button, the motor is on but...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=678083
Generic problem for all Vacuums
Hi, I have an Electrolux Ambassador
Posted by greenforest on Jun 17, 2008
Hi, I have an Electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the Electrolux stop (has happened before) and when I pressed the reset button, the motor is on but the wheel does not spin. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 17, 2008 | Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Need a replacement drive belt for my hoover lark u4043 not sure about last no. it's an old machine, but this one is in perfect condition, minus the drive belt. my local vacuum specialist says they can't...
Hi
As you know the Hoover Lark was more or less a rebodied Hoover Junior. The U4043/ (are you sure its not U4034?) model should use the same round drive belts as the Hoover Junior 1346 so youre looking for the old rubber ring type belts which are circular rubber rather than the flat types (usually ribbed) for the later 1980s U1104 series. You can find these types almost anywhere these days as these cleaners go on for ages.
Apr 19, 2008 | Vacuums
Minuteman ambassador jr. shampoo extractor
roro, There are two possibilites: One is that each hose does something different (suck and exhaust) or both suck. Find the one that sucks. That should be the one that you hook tools to now. If the attachment has an electrical connection, it will be needed to do scrubbing. If the shampoo unit is from a different brand, you'll have to make up something to do that. If you do, be certain that the connection is fully taped up so no liquid can get to it!!
Dec 06, 2007 | Vacuums
Minuteman C46000-00 Self Contained Carpet Extractor Vacuum Logo
69 people viewed this question
Top Minuteman Vacuums Experts
Marvin
Marvin
Are you a Minuteman Vacuum Expert? Answer questions, earn points and help others
