Question about Car Audio & Video
I've bought a 2010 toyota hilux. the factory radio model # t3802 has a usb port. is there a limit to the size of the flash drive i can use? regards rick
SOURCE: xbox 360 usb port
Ive never had a problem with my 160 GB portable hard drive
Posted on Jan 28, 2008
SOURCE: I bought a Simpletech signature
Your USB port is incapable of supplying the required amps of power. ALL these little 2.5" drives need up to 1000 milliamps of juice, regardless of who makes them. I have yet to find any PC that can supply more than 500ma from a single USB port (and even that is optimistic). That is precisely why several portable drive manufacturers supply a USB splitter lead to facilitate an extra 500ma of power. (But some charge extra for this lead).
SImpletech supply the splitter lead with the drive, so please try it, as it may solve the problem.
In addition, some makers, including Simpletech, provide a 5 volt auxiliary power socket on the drive case in (unacknowledged) admission that many people do not have a second spare USB port and that, even if they have, it isn't a reliable source of power anyway! Also, they don't supply the necessary PSU and they deliberately withhold the necessary specification for the needed PSU. You need a 5 volt, 1000 milliamp power adapter costing anything from $10 to $30 (ridiculous!)
These solutions should be tried before assuming the PCs USB port is faulty, because it 'probably' isn't.
Posted on Jun 23, 2008
jts4utotrip
  • 20 Answers
SOURCE: USB port malfunction
CHECK THE RATING ON YOUR POWER SUPPLY BECAUSE SOME LAPTOPS WILL REGISTER THE POWER CONNECTION PORT AS A USB PORT AND IF YOUR POWER SUPPLY VOLTAGE IS TO HIGH FOR THE COMPUTER IT WILL REGISTER IT AS SUCH, "HUB-PORT" IS SHORT FOR MAINBOARD PORT ON SOME DELLS. UNPLUG YOUR POWER SUPPLY AND CHECK THE RATING ON IT COMPARED TO THE DELLS INPUT VOLTAGE, THE INFORMATION IS NEXT TO YOUR SERIAL NUMBERS AND LABELS ON BOTH PEICES KEEP ME POSTED... JON-T
Posted on Dec 07, 2008
SOURCE: My 1995 Toyota hilux surf wont engage 4 wheel
Have you tried putting it into neutral then chucking it into low ratio?
Posted on May 11, 2009
AjayB
SOURCE: Samsung LA40C530 LCD USB limit
I have tested the LA40C530 Samsung with a 300GB external hard disk and it works well without any issue. My guess is that it should support 500GB as well. I have played video/music/pictures on my WD 300GB HDD.
Posted on Jul 09, 2010
Testimonial: "Thank Ajay, I will also try on a 500GB disk"
Hilux problems
reset it look in your manual for directions
May 23, 2014 | 2010 Toyota Hilux 2.5
My indicators don't flash when unlocking my hilux 2010
what indicators. say which, there are many.
Dec 08, 2013 | 2010 Toyota Hilux 2.5
HOW TO PLAY MUSIC IN MY CAR
You will have to buy an aftermarket radio that has a USB port that supports all media file types. (Most brands do) you would have to remove your factory radio. Buy a wiring harness that matches your make, model, and year of your vehicle. Attach harness and install the new radio. Plus hard drive into USB port and you're good to go. Don't forget to vote
Oct 17, 2013 | SimpleTech SimpleDrive 160 GB External USB...
2010 hilux under chassis repair the suspention to lift 4inches high
Reset the sagged springs if leaf spring. Fit aftermarket coils otherwise. Fit longer shockys so they don't bottom out. Check max operating angle of drive shaft joints as 4" will reduce their operating life and cause drive line vibrations fit extended shackles also on rear. While it looks tough remember the extra height raises the center of gravity of the vehicle making it unstable in most conditions.
Mar 03, 2013 | 2010 Toyota Hilux 2.5
Where is the fuse for the clock radio cig lighter in a toyota hilux 1993 model
Made a short circuit here radio, cig lighter ,air Con ,clock, windows, indicators are not working but hazards are working it is a toyota hilux
Oct 17, 2012 | 1986 Toyota Hilux 2200
Is ATI Radeon HD 4250 Graphics an OpenCL graphics card compatible with FInal Cut Pro X?
As "Final Cut Pro X" is an Apple program, you need to make sure you are using an "Apple" Operating System. It will not run on Windows.
Mar 27, 2012 | Computers & Internet
USB ports not working
jst see control panel usb setting or ur power scheme setings
Mar 23, 2012 | Toshiba Satellite A505 Notebook
I bought new hp usb flash drive 4 gb when i go to
you can try getting a flash for your bios to see bigger drives it is probably a size limitation in bios what operating system are using and how old is the computer
May 09, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
Usb ports
Check to see if your flash drive or printer needs drivers in order to work properly. If not, then it could be the drivers for the usb ports or you have faulty usb ports. They're supposed to catch it at the factory, but it happens from time to time on new machines.
Jun 20, 2008 | Toshiba Satellite A135 Notebook
Xbox 360 usb port
4GB is the limit on the usb devices.
Jan 04, 2008 | Microsoft Xbox 360 Console
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
