Question about GE Advantium 120 Convection/Microwave Oven
MICROWAVE DOES NOT HEAT ADVANTIUM 120 - GE Advantium 120 Convection/Microwave Oven
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
If it is the type with an "Invertor", they are not user serviceable and should be directed to an authorised repair agent for continued safety, otherwise if conventional;
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 24, 2011
  • GE Master
  • 6,771 Answers
Unfortunately this is all to common problem with different brands, the magnetron is more than likely the issue, "heats food" however there are two additional parts that can be a factor, the high voltage capacitor and diode, chances are the cost to repair will be higher than a new replacement.
MicrowaveSvc
  • 9098 Answers
SOURCE: Advantium 120 door handle breakage
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 31, 2009
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Posted on Apr 17, 2009
highspeedsan
  • 61 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Posted on Apr 27, 2009
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Problem with the GE Advantium (model sca1001fss01) Convection / Microwave Oven Everything works except the microwave. It makes a sound like its working, table turns, but does not heat or cook.
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Jan 29, 2011 | GE Advantium 120 Convection/Microwave Oven
My advantium lights, turntable turns, timer works, appears to be working as usual, but does not heat..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
How to replace light inside of Advantium 120 oven
I am looking for the same... How to replace the light inside the Advantium 120 oven. Any answers out there?
Jan 04, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium 120 . The panel lights up I do not get an error code the timer works but it does not heat up. what could cause this
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Jul 05, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
321 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
