Question about Samsung HP-T5044 50 in. Plasma TV
I brought a wall mount for my hpt5044 but the holes and screws dont line up do i need an extension
  • 643 Answers
The mount manufacturer may have extensions for the mount. if not you may have to purchase the one designed for that tv. Try Sanus mount finder.
Posted on Mar 24, 2011
What size mounting screws emerson lf320em4f
lf320em4 takes a M4 20mm long. Beware, on the lf320em4 the mounting holes are directly in-line with the HDMI input jack.
Jan 06, 2014 | Televison & Video
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
first get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
Jul 01, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
Is plasterboard (with battens behind) strong enough to install a Roca Kalahari wall-hung sink against or do I have to reinforce it using tiles or a bracket?
Ok. Big answer. Where the sink is going to be mounted there needs to be inside the wall structural support mounted between the wall studs. This could be a 2X6 or 2X8 nailed from one wall stud to the next at the height the sink will be mounted. Then once you have repaired the sheet rock you can measure the distance the mounting holes in the back of your sink are and drill these holes smaller than the mounting bolts/screws for your sink. Screw the screw portion into the wall using the nuts on the bolt side and a wrench. Remove the nuts and the slide sink into place where the bolts/screws fit into the mounting holes in the sink back. Install washers and nuts and tighten to wall.
Sep 01, 2010 | Roca Pacific Semi-Recessed Basin - Black
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
I want to mount my tv on the wall and i do not which screw do i have to remove from its back
No you dont need to remove the back it actually has holes for the mount already just buy an universal mount that fits your TV and use the screws that comes with it.
Dec 24, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
How do you install wall mount mailbox into brick house?
Make a new hole in the wall; the old one will be covered by the box. Depends to some extent on what the wall is made of, though. Can you drive a screw in and get it to hold, or do you need to use a plastic wall anchor?
If you're happy with the old location, start one screw in one of the old holes to begin with, just to hold the box in place temporarily. Level the mailbox, and mark the hole location of the other hole on the wall with a marker. Then swing the box out of the way, or take it down, drill a pilot hole for the other hole's screw. If required, insert a plastic wall anchor there, suitable for the screw you're using, then reposition the mailbox and insert screws.
If it's a masonry wall you'll need a masonry bit to drill the holes, and you'll have to be careful to line them up well. In that case, you might be just as well off back up the inside of the mailbox with a block of wood and drilling a new hole in the back of the mailbox to line up with the old hole. Just measure carefully, and use a center punch or nail set to make a dimple before trying to drill a hole in the metal.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 09, 2009 | Fulton Corporation Fulton 700m Wall Mount...
Can i wall mount this
Usually, UMC include the screws already screwed into the wall mounting holes that you should use to attach a wall bracket. This is so you dont then go and use longer screws often supplied with wall mounts that are way too long and can damage the parts inside the TV.
Dec 18, 2008 | Toshiba 20HLV16 20 in. LCD Television
How to mount the 26" tv on a swivel wall mount?
No dont do that ! you will need to buy a wall mounting unit...you can find at best buy wall-mart and other electronic stores!
Dec 11, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Samsung HP-T5044 50 in. Plasma TV Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
