Question about Royal HG140MX Shredder
The shredder won't start when paper is inserted. model HG140MX I have recently shredded dozens of cd.dvds. It worked fine. Now when paper is inserted, it does not begin. Green light is on and bin is inserted.
SOURCE: DM15C stops after 4 seconds, open bin light comes on
This solution worked great! Thank you
Posted on Apr 15, 2008
geemarie
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
  • 35 Answers
SOURCE: The shredder jammed (too much paper) then stopped
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Posted on Mar 08, 2009
rulds2008
  • 3866 Answers
SOURCE: shredder won't come on
The question would be is it getting power!!! if so the motor went bad thus causing this to fail i cannot beleave yuo shred DVD's in this even know it says it can you are still putting alot of strain on the motor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
My shredder plugs up every 20-30 sheets of paper. I unclog it and after 20 or so sheets of paper, its clogged/overloaded again.
please check underneat the cover ,how many minutes you can shred.and how many minutes .you are suppose to pause
mp
Oct 19, 2014 | Royal HG140MX Shredder
SHREDDER CONTINUALLY SAYS OVERLOAD EVEN THOUGH 2 SHEETS OF PAPER ARE INSERTED
It might need cleaning; mine had the shredded paper jammed in by cutters and some shreds got between the gears. First, try using a "cleaning sheet": a piece of paper lightly sprayed or smeared with vegetable oil or spray cooking oil. If that doesn't do fix it, the shredding mechanism, which has many parts, some of which are sharp as razors, might need to be disassembled and cleaned. Though I did that disassembly and cleaning, I would not recommend it to the casual DIY-er.
Sep 08, 2014 | Royal HG140MX Shredder
My Staples Shredder, model # SPL-S302D will stop shredding in the middle of a job or immediately after starting to shred. It is a strip-cut style shredder, I use lubricating sheets once in a while on it,...
You can clean the sensor with a alcohol and be sure there is no jam occur. If it doing fine then it's work and there's no more problem. Always clean it, a jam can cause motor to heat up and it's winding will be burnt.
I hope my advice help you.
Jun 06, 2011 | Office Equipment & Supplies
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
When you put paper in it starts to shred for about 1/4 inch then goes to reverse. No jams that I can see. Can run forward and reverse without paper with no problem. Sensor problem?
No mention of make or model however this holds true for all shredders.... especially if its a "cross-cut" shredder; put some shredder oil onto the cutting shafts where you insert the paper this will help get rid of some of the build-up that occurs due to the shredding process...also give the "eyes" in the middle of the "throat" a clan with a soft cloth( unplug the machine first or it will start to run and take your cloth in.) Occasionaly shrd a sheet of paper with some shredder oil poured directly onto the paper..this will help lubricate the cutting blades. Lastly...only shred up to about 70% of the rated cpacity..this will result in fewer jams an longer machine life.
Oct 19, 2010 | OfficeMax 0M96431 Shredder
Turns on when paper in slot, but won't pull it through to shred.
must disassemble feeder unit. you will find many bits of shredded paper to pull (push) out with a long narrow tool like a crochet needle.
Jun 19, 2007 | Royal AG10X Shredder
Royal HG140MX Shredder Logo
55 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
