Swift Ultra-Lite 763 ZWCF (8x32) Binocular Logo
Posted on Mar 24, 2011
I own SWIFT 8x32 Model #763 Ultra-Lite binoculars. The right diopter adjustment cover came off. I can put it back on but it does not seem to adjust - I think it is slipping since it is not attached to the lens properly? Is this something that can be fixed?
3 Related Answers
Anonymous
  • 26 Answers
  • Posted on Jun 24, 2009
SOURCE: I have a Swift model 802, 7X35 binocular. The
at the bottom hindge there is a nut you can remove . then take a long thin screwdriver and take off the screw that holds the eyepiece focus shaft. turn center wheel till eyepiece xbars come off body,carefull not to touch lenses. gl [email protected]
Anonymous
  • 32 Answers
  • Posted on Nov 04, 2009
SOURCE: I hace a pair of swift ultra light binoculars and
i would take one out of the other side and take it to a hardware store and see if i could match it up with some thing.
Anonymous
  • Posted on Oct 26, 2010
SOURCE: Eyecups are sticking on my Swift ultra light binoculars
The rubber outer ring of the eyecups can be peeled off of the metal ring underneath. This exposes the three tiny screws and their channels that allow the eyecups to move in and out. Clean any debris out of the channels, tighten or replace the screws if necessary, and fit the rubber covers back onto the rings.
How to collimate Nikon Venturer II10x23 6.3 degrees compact binoculars?
Here are the steps to collimate your Nikon Venturer II10x23 6.3 degrees compact binoculars:
1. Adjust the diopter: The diopter adjustment is usually located on the right eyepiece, and it helps to adjust the focus of the image for your right eye. Close your left eye and adjust the focus of the right barrel using the diopter adjustment until the image is clear.
2. Look at a distant object: Choose a distant object, such as a building or tree, and focus on it using both barrels. Keep your eyes on the object while you perform the next step.
3. Adjust the barrel alignment screws: The barrel alignment screws are located on the hinge that connects the two barrels. You may need a small screwdriver to adjust them. Use the screws to adjust the alignment of the barrels until the images in both barrels are aligned. If the image on the right barrel is above and to the right of the image in the left barrel, you need to adjust the right barrel downwards and to the left.
4. Test your binoculars: Once you have adjusted the alignment screws, check the alignment of the barrels again by looking at a distant object. If necessary, make further adjustments until the images are aligned.
5. Repeat the process: Over time, the alignment of your binoculars may shift slightly, so it's a good idea to check the alignment periodically and make adjustments as needed.
How to hold binoculars properly
1. Remove the lens covers, if they are in place.
2. Set the diopter on the right barrel eyepiece. The function of this setting is to adjust between vision differences between your eyes if you are NOT wearing corrective lenses. Set to zero if you do have corrective lenses on (glasses or contacts). For proper diopter adjustment see this article: Binocular Selection Guide.
3. Most binoculars will hinge in the middle to allow for differences in the spacing between the eyes. Set the spacing to fit your eyes.
4. Adjust eye cups. Each eyepiece will have a means of maintaining the correct eye relief for the user. On quality binoculars the rim of the eyepiece will extend and retract as you twist the eyepiece rim. Move all the way in if you are wearing eyeglasses or adjust out if not wearing eyeglasses. You will know if they are set correctly when you look through the binoculars and check to be sure that the circular edge of the view should be sharp and not fuzzy. At this point we are not looking at any object in the view but rather the perimeter of the view. You may need to adjust the eye cups again to compensate. On lower cost binoculars the eyecup may only be a rubber lip that you either fold over (the "in" position) or out.
5 Raise binoculars to your eyes and use one finger to adjust the focus wheel on the center shaft between the two barrels, until the view is in sharp focus. If viewing for extended periods you may want to keep your elbows down near your side as this will increase comfort while viewing.
Final safety tip: Do not look at the sun through binoculars.
Many people enjoy observing nature with binoculars. Having them handy is key. Hunting, astronomy, marine use, and stadium sports are a few more activities where having a pair of binoculars can make a real impact to your experience.
Cannot focus single focus side of monarck binoculars
First you must focus the left eye on a given object with the center focus wheel. Once the left eye is sharp while looking at the same object adjust the right eye to be as sharp as possible. The right eye diopter is only meant to adjust for the small differences between the eyes.
Thomas E. Kuenzli Eagle Optics (800) 289-1132
The left eye piece on my Minox 8x32 binoculuars isn't working properly. It doesn't adjust. How can I get it repaired?
In the US, you can contact Minox at 603-469-3080. You'll likely need to send them to Minox for repair service. Their offices out based out of New Jersey.
Regards,
Ben
Ben Lizdas
Sales Manager
Eagle Optics
www.eagleoptics.com
I hace a pair of swift ultra light binoculars and have lost 2 screws in one of the eyepieces. Where can I get replacements>
Diopter out of ajustment
pentax is one of the good guys and has a great serice center. why no send it back and ask for a replacement, if your sure you are focusing properly there should be no problem. [email protected]
Insta-Focus focusing problem
first open and close the binoculars untill they fit you eye width,now adjust left eye with the flat section located on the center hinge,now turn right eyepiece till clear. note: once you have adjusted right eyepiece you only have to leave it in that position in order to focus from near and far.........good [email protected]
Diopter adjustment
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Top Swift Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Swift Optic Expert? Answer questions, earn points and help others
