Question about Casio GW1500A-1AV G-Shock Atomic watch
1500a, the alarm is off, the hourly beep/chime is off but every night between 1 and 2 the chim beeps 8-10 times...does this have something to do with the sync feature. What could be causing this, it's like an unwanted alarm every night.
4 Suggested Answers
SOURCE: Alarm/Beep
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Posted on Mar 06, 2008
SOURCE: how to fix chimes on seiko chimming clock
When to music plays it is ok but, when the chime occures it acts like it is under water.
Posted on Jan 31, 2010
SOURCE: Coleman wristwatch - alarm and chime keep beeping
Hey, I had the same problem with my Coleman watch. It would alarm at midnight. I used the mode feature like the poster before me said. When I got to the alarm "screen" I used the button that backlights the watch's screen. The light came on and the alarm feature was removed. I hope this helps.
Posted on Jul 06, 2010
How do I turn off the beep chime signal on casio f91w?
In a few words, here is how:
1 - Push button C to get to the ALARM mode
2 - Push button A to cycle through the options:
First, you will get daily alarm activated only,
then, only hourly beep signal,
then both daily and hourly signal chime
and finally both hourly signal and daily alarm turned off
3 - Push button C to return to the Time Mode
I try to make it short and straight to the point,
I hope you find it helpful!
Phil
Sep 28, 2017 | Casio Watches
How to desactivate only the hourly chimes alarm, in my taksun ts 613A
ask them. the manual doesn't appear to be available online.
Address :
Unit 9, 32/F., Cable TV Tower, No.9 Hoi Shing Rd., Tsuen Wan, N.T., Hong Kong
Tel :
852-2419 8831
Fax :
852-2408 1575 / 2409 0136
Contact Person :
Ms. JoJo Yeung
Email :
info@takshun.com.hk
URL :
http://www.takshun.com.hk
Oct 27, 2015 | Watches
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
I want to set the watch to beep or chime on the hour.
When you are setting alarm, there will be visible sign of loudspeaker or bell. Toggle with buttons and when the sign is visible in normal mode (ordinary time showing mode - everyday wear) the beep will alert you every hour. Be aware - there are hundreds of people asking how to disable this function, simply because it gets annoying after a few days - it works during the night time as well.
Apr 03, 2011 | Watches
I have a xonix watch that chimes every hour, how do I stop this?
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Sep 27, 2010 | Watches
Aw60447w digital watch. I cannot turn off the hourly beep. help
Hourly chime on/Off:
1.) Press and hold the lap/reset button (bottom right) to display alarm time
2.) While holding lap/reset button, press the mode button (bottom left)
3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
Alarm On/Off:
A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
Jan 26, 2010 | Swi Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Aug 12, 2008 | Timex 27191 Wristwatch
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Casio GW1500A-1AV G-Shock Atomic watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
