Question about Labtec LCS 2408 Computer Speakers
Re the Labtec 2480 Computer Bass speaker. I'm a little puzzled about connecting an AC transformer to a DC input. Also, is software needed to activate the speaker? As I'm using it on a Mac G4 I'm tempted to bypass the interior circuitry and hook the speaker up direct to my Harm/Kardon system which has an output for a bass speaker.
5 Suggested Answers
SOURCE: no wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Posted on Aug 23, 2009
rommelalilin
  • 2178 Answers
SOURCE: I need a AC/DC power
Radio Shack
Posted on Jan 14, 2011
SOURCE: No left channel output from
Audio output chip TEA2025B. I'd replace both. http://search.digikey.com/scripts/DkSearch/dksus.dll?site=us&lang=en&keywords=tea2025b
Posted on Feb 14, 2011
gopakumarg43
  • 75767 Answers
SOURCE: I have a Labtec 2408
Hello
A [13.5V 6Amps AC] transformer is sufficient to drive its internal circuits. OK.
Posted on Mar 24, 2011
Hiw many mA does the adapter for labtec lcs150 speakers need
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Mar 29, 2013 | Labtec LCS 150 Computer Speakers
NEED TO REPLACE POWER SUPPLY
Nov 12, 2012 | Labtec LCS 150 Computer Speakers
I just wanna check was my little mark 250, older version, ever been opened or changed in any way. I was at the guy that opened it and told me that because of the input power of transformer that is about...
when using amps,, you can't go by the number of the amp to determine what wattage the unit puts out, after checking on this amp,, the white marks that your seeing on the cable, is probably just some of the thermal paste that you apply to any heatsink or CPU ,, nothing to worry about, now as far as the wattage,, here is what they say about that amp, so there is a difference between the 4 and 8 ohm set ups
The Markbass Little Mark 250 bass amp head is a high-quality bass amplifier with a solid-state preamp and an analog power amp. The Little Mark 250 delivers 250W of power into a 4 ohm cabinet, or 150W into an 8 ohm cabinet. This Little Mark has a 4-band EQ, Markbass' VLE (Vintage Loudspeaker Emulator) and VPF (Variable Pre-shape Filter) filters, as well as both Gain and Master volume controls. The front panel accepts both a passive or active bass 1/4" input, as well as a balanced XLR input for acoustic bass pickup systems or a microphone. On the rear panel you'll find a Neutrik Speakon combo jack output that accepts both Speakon or 1/4" speaker cable as well as a second 1/4" speaker out jack. You'll also find a balanced XLR out, unbalanced tuner out so you can tune as you play without passing your signal through pedals, and a Send and Return Effect loop which saves you from losing your signal if one of your pedals dies or a cable in the chain gives out.
Aug 02, 2011 | Markbass Little Mark 250 Bass Amp Head
Can I connect a Labtec Model AD-SS-3 to my laptop?
This model of AC adapter puts out 14.4 Volts of DC current, at 1.0 Ampere.
I doubt that 1.0 Ampere is enough amperage to run your computer, or to recharge your computer's battery.
Look on eBay for the model-number of the original AC adapter.
You might find one from the manufacturer of your computer,
or you could find something that will be compatible in voltage/amperage.
Aug 19, 2010 | Labtec LCS 2414 Computer Speakers
I need a new power supply for Labtec LCS 1030 speakers and trying to obtain specs and power plug information. Anybody have the information available?
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
Feb 17, 2010 | Labtec LCS 1030 Computer Speakers
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Labtec LCS 2408 Computer Speakers Logo
29 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
