Question about Dryers
The dryer just makes a buzzing noise like it wants to start but just doesnt start. After I keep pressing the button it stops trying to start. Someone told me it's probably the belt. If so, is it an easy fix?
  • 96 Answers
If you get a friend to help, try opening the door and with one hand push in the door switch, with the other hand, turn the drum clockwise while your friend pushes the start button. If it runs, you have a bad start winding in the motor or the centrifugal start switch is stuck in the run position. either way, you need a new motor:o(
Posted on Mar 24, 2011
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have a ge profile refrigerator and it works fen except it ekes buzzing. The ice lock/lock function, no body is pressing the button but it keeps locking and unlocking itself and the buzzing/beeping i
The switch that does the lock/unlock has got wet inside.
Make sure you can see the back panel of the switch and use a hair dryer to warm the panel back and the front of the switch. When it gets warmer it may dry out and start working normally.
Dec 21, 2013 | GE Refrigerators
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
GE Heavy duty Dryer will not start when ''start button'' pushed...will make a loud buzz, starts for anything from 10 -20 seconds if I keep finger on the button then goes off I have to keep returning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | GE Dryers
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
Top Dryers Experts
