Question about Nikon COOLPIX L18 Digital Camera
How do I set camera to shoot on continuous? - Nikon COOLPIX L18 Digital Camera
  • 2,574 Answers
Press the shooting mode button in shooting mode to display the shooting-mode
selection menu and set the shooting menu to Continuous.
Note:The maximum frame rate with continuous shooting may vary, depending upon the current image mode setting and the memory card used.
Posted on Mar 24, 2011
How to use continuous shooting on canon powershot sx40
Set your camera to high speed continuous shooting, track the action, and just before the peak press and hold the shutter release button. The camera will take a series of pictures and hopefully one of them will catch the action at its peak.
If you're asking how to set the camera for high speed continuous shooting, Turn the mode dial to SCN, press the FUNC/SET button, select the overlapping rectangles, and press the DISP button. Full details are in the "High-Speed Continuous Shooting" section of the manual (page 74 in my copy). If you need a manual you may download one here.
May 09, 2012 | Canon Cameras
I am looking to learn how to set the camera to take a sequence of delayed shots..how do I do this..?
The camera shoots continuously while the shutter button is held down.
there are three options for it
Continuous(Approx. 4.0 img/sec)
Shooting AF (Approx. 1.1 img per secnd)
Shooting LV (1.2 images per secnd)
(Live View)
Press teh shutter button.
Use up and down buttons to select the shooting modes.
The camera will continue to reord continous images as long as the shutter button is held down.
The taking will cease when it is released.
Feb 05, 2011 | Canon PowerShot SX1 IS Digital Camera
I can't set my Nikon S560 to continuous shooting mode. When I scroll the menu, it jumps over the continuous setting. What am I doing wrong?
Q: I can't set my Nikon S560 to continuous shooting?
Ans: try after setting, Shooting Menu -> Distortion Control -> 0ff
Sep 06, 2009 | Nikon Coolpix S560 Digital Camera
I have nikon d40, on continuous mode, auto, it doesn't shoot continuously. also, most of the time, it focuses but not shooting... please help.
I don't know what you are doing - mine shoots continuously with no problems. There is nothing to set other than to set the shooting mode.
I have noticed that some memory cards are so slow it doesn't allow continuous mode. I recently replaced mince ith 16G class 6 cards and they work fine.
Jun 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Frame full
I had the same problem with a fujifilm camera, the good news is that it's easy to fix. On the shooting menu (press menu when the camera is in shooting mode) there will usually be a set-up option, within that you should see "Frame No." or something similar- the two options for this are either "continuous" or "renew". If you are experiencing the Frame no. full error it means that you are currently set to continuous; TO SOLVE THIS PROBLEM SWITCH THIS SETTING TO RENEW.
Hope this helps!
Apr 05, 2009 | Fuji FinePix Z5fd Digital Camera
Continuous mode
i think the frame rate is 1.3 frames per second.
Issue:
How do I set Continuous Shooting?
Solution: Setting Continuous Shooting mode PowerShot SD750 and SD1000.
Continuous Shooting In this mode, the camera shoots continuously while the shutter button is held down. Recording ceases when the shutter button is released. In addition, under the following conditions, continuous shooting can occur at a consistent interval until the SD card is full*.
  • A resolution and compression combination other than 145.gif and 129.gif is selected.
    * If continuous shooting suddenly stops, the SD card may be full.
Continuous shooting is available in all modes except 171.gif[AUTO], stitch_assist_icon.gif[Stitch Assist], coloraccentdropper.gif[Color Accent] and colorswapdropper.gif[Color Swap].
To set Continuous Shooting
  1. Press the cont_icon.gifbutton to display cont_icon.gif.
  2. Shoot the image.
    The camera will continue to record successive images while the shutter button is fully pressed. Recording will cease when the shutter button is released, the card is full or the card does not support a write speed to allow continuous shooting to continue.
To Cancel Continuous Shooting
  1. Press the cont_icon.gif button twice to display single_icon.gif.
caution_a70.gifTo enhance the continuous shooting performance when you suspect the speed has dropped, you are recommended to format the SD card in the camera (Low Level Format) after you save all its images to your computer. note_icon_a70.gif
  • The interval between shots may lengthen slightly when the camera's built-in memory fills.
  • If the flash is firing, the interval between shots will lengthen to accommodate the flash's charging requirements.
Feb 18, 2009 | Canon PowerShot SD1000 Digital Camera
Instructions ''continuous shooting'' for canon powershot sx110 is
Continuous shooting mode is not available when in Auto, Movie, or Stitch Assist mode. You must select P, Av, Tv, M or one of the preset shooting modes to be able to select continuous shooting. If you didn't get a manual with your camera, you can view / download one here.
Nov 25, 2008 | Canon PowerShot A75 Digital Camera
Fuji s9500
there is (quite annoyingly) no way to set up a default
Oct 29, 2008 | Fuji FinePix S9500 Zoom Digital Camera
Nikon D80 - Continuous shooting
I will need more info on the settings you are using. It might be that the camera is in a specific mode which is not allowing you to take continuos shots.
Mar 22, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
137 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
