Question about AcerScan 1240UT Flatbed Scanner
I have a windows 7 computer and a scanprisa 124 out. My computer doesn't recognize the scanner. Any sugestions?
  • Acer Master
  • 1,381 Answers
Hello mariafecbato ,
The manufacturer doesn't offert any support for your device with Windows 7 .
If you absolutely don't wan't to buy a new one , there is a work around :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
I have Win 7 on my primary and installed Win XP on my secundary . Works like a charm .
Have a nice day ,
Best regards,
Fanaudi .
Posted on Mar 24, 2011
Is there an updated Acer ScanPrisa 124Out driver compatible with Windows 7 anywhere?
Unfortunately, there are no Win7 drivers for this scanner. THe drivers are for Windows 98SE through XP. The support for the ScanPrisa 1240UT is available here: http://benq.co.uk/support/downloads/downloads.cfm/dtype/M/page/downloads/product/87 . Click on the Drivers tab.
The XP driver may work under Windows 7 32-bit in the Compatibility Mode. (To check your version of Windows 7, click Start > Control Panel > System and Security > System. If the Windows version title ends with x64, you do not have the 32-bit version. Otherwise, you do.) To use this driver in Windows 7 32-bit, download the .zip file and extract it. (Right click and choose Extract All.) Then find the installer (Setup.exe) and right click again and select Properties. Click on the Compatibility Tab and check "Always run this program as compatible with" and fill in XP in the drop down menu. Right click again and choose Run As Administrator.
If you have Windows 7 64-bit, you will need to use a computer with the older version of Windows. This can be a virtual computer (if your hardware supports it), a dual boot machine, or a physical second computer. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP computer for free (again if your hardware is capable of doing it). In that case, download Virtual PC and XP mode from Microsoft. Install the programs in order. Then install the scanner using the drivers from the above link as if the XP mode is your regular computer. Other virtual computer programs include VMWare and Parallels. However for those and the other options, you will need a licensed copy of the older versions of Windows. (If you know a Windows User's Group member, you may have a source for older versions of Windows.)
I hope this helps.
Oct 14, 2011 | Acer ScanPrisa 640P Flatbed Scanner
Problem to find a driver for the sacnprisa 640p, acer
my scanner scanprisa 640p does not work on windows xp
Oct 15, 2007 | Acer ScanPrisa 640P Flatbed Scanner
Acer ScanPrisa 640P driver for Windows XP
Hi
This Is mayank
I have Acer Scan Prisa 640 P
I need the drivers for my scanner
I have went to the site but i was not able to Get the drivers
Plz send the link to download the drivers
OS : Win XP service Pack 2
Oct 10, 2007 | Acer ScanPrisa 640P Flatbed Scanner
Driver for Acer scanprisa 640P (XP)
You can register for free on this site, then download the driver for your scanner. http://www.scanner-drivers.com/drivers/77/77791.htm
Apr 17, 2007 | Acer ScanPrisa 640P Flatbed Scanner
AcerScan 1240UT Flatbed Scanner Logo
221 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
