Question about Vizio E550VA 55 in. LCD TV
How do you adjust the Bass & Treble on the E550VA LCD HDTV. I did what the manual said to do but when I try to access the setting it just skips over the B&T setting. The music is so loud during movies that we have to turn the set up to 50 sometimes just to hear what is being said, And we did follow the turn the SRS Truesurround off as directed in manual. I purchased the set from COSTCO last month
Turn off the surround sound and true volume. Then it will let you access the bass and treble.
Posted on Apr 08, 2012
SOURCE: Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Posted on Nov 26, 2007
tvtek
  • 1284 Answers
SOURCE: Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Posted on Feb 23, 2007
sgregg
  • 133 Answers
SOURCE: NO picture
Make sure the video cable supplied with the TV is secured to the correct video
output port on the back of the VCR and the TV. Make any cable you have attached
to the TV is secured to the correct output your Set-Top Box, DVD, etc.
Adjust brightness and contrast.
Check Source settings.
Let me know if this does not help and ill look for anything else. Other than this is something internal and will need to be serviced probably
Posted on Oct 20, 2007
  • 1779 Answers
SOURCE: sound issues...volume goes up really
Make sure surround sound is off in your audio menu. Put it on just STEREO...
Posted on Dec 20, 2010
SOURCE: I just bought the Vizio E421VA and I am
we have had the same problem and I suggested to Hubby that we had better return it soon. He did some research and we are trying this: use the TV remote and press the center button "Select", Choose Audio, Make sure True Volume is set to On. I've only been watching for an hour but it very well may have solved the problem. Hope it works.
Posted on Feb 26, 2011
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How to change treble & Bass
As crazy as it seems, I couldn't find any references to bass or treble in the manual (linked below for your convenience). You might want to contact Sony for more help with this.
https://docs.sony.com/release/DAVC700.PDF
Apr 11, 2014 | Sony DAV-C700 System
Wanted to adjust quality of sound, such as treble
Go in ur menu pick the audio go down pick the reset the tv set back to factory setting will get the
Mar 24, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Aug 24, 2008 | Alpine CDA-9833 CD Player
Vizio E550VA 55 in. LCD TV Logo
569 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
