Question about Cell Phones
My sciphone i68 4g will not allow me to change modes, (stuck on wifi only) (wifi only,gsm only, wifi pref. and gsm pref, it says unfinished also it says not allowed to dial phone
  • 2 more comments
  • lockwood0 Mar 24, 2011
    yes i want more help the phone accepts incoming calls but will not go out of wifi only mode and won't let me dial. when i try to change modes it says unfinished also when i try to dial it say not allowed
    please i dont know where all of this stuff is located. please guide me with this thanks
    tried that did not work, sorry that was the first thing i did
    President:
  • 1,738 Answers
Thanks for visiting FixYa!
You need to do a Hard Reset. This will remove all information you have put in your phone and all apps you've downloaded to it.
This is used to restore your phone to the default settings as it leaves the factory.
Use the up/down key to select the options of "Restore to factory settings" and then click
the left/right functional key on the bottom left side of the screen. Enter the correct phone
lock code as instructed (default password is 1122). Reboot your phone after completion as
instructed.
Posted on Mar 24, 2011
    President:
  • 3,278 Answers
Hello.
Could be a SIM card issue, if you moved the SIM card from another phone.
If not the SIM card .. did this phone ever work ? Is it still under warranty ?
Hope this helps.
  • NinaE Mar 24, 2011
    Hello, again.
    See if this can work for you:
    1. turn off the phone
    2. place 2 sims on the phone
    3. restart the phone
    4. keep the WLAN disabled
    5. enter the engineering mode * # 82043036 #
    6. select the option RF Test Tool (on my phone it's option 13)
    7. Select GSM, to accept him
    8. go to Power scan
    9. go to Band Select and select OK DCS1800
    10. another screen will appear (model F003) look at each of the options until
      you find one that will have your phone appear unresponsive (this locked)
    11. pressing the main button (the box) will take you to the home screen
    12. go to the setup menu
    13. go to network settings menu SIM1
    14. this is a preferred mode
    15. select one of the preferred modes GSM or WLAN
    16. restart the phone and you should be ready to make calls
    Hope this helps.
I cannot dial out I Problem with the Cellular Phones I cannot dial out I get a message Not allowed to dial. Also in the upper left I see wlan on I go to network setup then Preferred mode select GSM...
Please try this and let me know if it works.
  1. Change to flightmode.
  2. Then power off the device.
  3. Restart it and change to normal mode.
Also do a factory reset. The default passcode is 1122.
Apr 14, 2011 | Cell Phones
Hey I have a problem, my chineese iphone 4- when i try to call it makes a message: " not allowed do dial" and I can't change my prefferred mode from WLAN only to GSM only.. how to fix it?...
Not Allowed to Dial Error Message on a SciPhone i68 4Gsciphone-i68-4g.pngI recently purchased a SciPhone 4G with a dual sim card phone. I was very happy with this phone. I had no problems until one day I couldn't call out. I kept getting a not allowed to dial message every time I tried to call anyone.
I could still receive calls and send and receive texts but I couldn't call out. After quite a bit of research on the internet I came up with a solution. None of the solutions available had all the information I needed I just kept trying different combinations until it worked.
Here is the step by step solution I used to remove the "not allowed to dial" message and allow me to dial out again.
  8. go to Power scan
  10. another screen will appear (model F003) look at each of the options until you find one that will have your phone appear unresponsive (this locked)
  15. select one of the preferred modes GSM or WILAN
sciphone-i68-4g.jpgYou just enter the code/s into the phone number area in the dial section and the phone will recognize it and enter into the proper mode.
I still love this phone. It has built in WIFI so I can surf the internet with out having to have a data plan from my service provider. I use T-Mobile.
Here are the particulars on my SciPhone:
Mode: i68 Quad Band Phone
Specifications:
  • Dual SIM
  • Dual Standby
  • WiFi
  • Bluetooth
Mar 17, 2011 | Cell Phones
I am unable to change connection Network Setup > SIM1 network setup > Preferred mode I am stuck in "WLAN only". When I select "GSM" or "GSM preferred". The phone states "mode switching" and then...
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
Sep 05, 2009 | Dual Electronics CECT P168 Cellular Phone
"Not allowed to dial" new c5000 wi-fi phone
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
e-mail me to akiss_bd@hotmail.com if any questions..
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Not allowed to dial on the f003 Fly ying phone
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
Aug 26, 2009 | Dual Electronics CECT P168 Cellular Phone
Mi F003 show the error NOT ALLOWED TO DIAL tis is a video of the error: http://www.youtube.com/watch?v=bhJj21J6z_M Thank´s
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
email me to akiss_bd@hotmail.com if any questions
Jun 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
326 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
