Question about Microwave Ovens
The glass tray no longer turns. - Microwave Ovens
  • Microwave Ovens Master
  • 6,771 Answers
The turntable motor that turns the glass tray has become defective, the only way to fix this, is the motor must be replaced.
Posted on Mar 24, 2011
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Kenmore elite microwave/vent hood model 721.80834500 turntable
I bought a Kenmore Elite Microwave Hood Combination Model 721.80823500 at Sears. The installer did not bring the parts to connect the vent to the pipe on the ceiling and never came back. I cannot find the vent/exhaust connetor part to have it installed. No one knows. I appreciate information or installer. Thanks.
isabelmvaldes@gmail.com
Nov 16, 2008 | Kenmore 63792 Microwave Oven
Rotating ring/ Glide tray comes off the track -Elite Model 80803
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
Feb 20, 2008 | Kenmore 80809 Microwave Oven
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Turntable no longer turns
That would be the turntable coupler.
For more help from Emerson : http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Nov 25, 2007 | Microwave Ovens
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
Turnaround glass tray problem
Sometimes they get heated up and bend up in the middle so they don't make good contact with the coupler. The way I fix this is to heat the support over a stove flame, then place a heavy weight on it so it holds the legs up in place a bit until it cools. Here it is step by step: 1. Apply heat at points where each legs meet the hub (stove flame) 2. Place end of each leg on an object so that the bottom of the hub is held up about 1/8" off the work surface. 3. Place heavy object on hub so the bottom touches the work surface. 4. Let it cool. 5. Test it. 6. If it still does not work, increase the height of objects in step two. See: http://207.234.249.73/mwd/turntable_support_fix.gif
Mar 26, 2007 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
