Question about Panasonic DMR-E55 DVD Recorder
Hi, I converted VHS tapes to DVD using my Panasonic DMR-E55 recorder. I finalized the DVD's; my problem is - I can only play the DVD's on my Panasonic recorder. They do not play on anything else. This is a huge problem. Wondering if you have any suggestions. Thank you. Jackie
    New Friend:
    Problem Solver:
  • 18 Answers
I have found only -R and RAM discs are useful on the DMR em-55.
RAM are more expensive and can be edited which is why I bought the unit. RAM discs are best played in a Panasoinc player, but some Samsung recorders will play the RAM. In fact, a Samsung may play a -R that is not finalized, but don't expect it to go back to the EM-55 and don't expect it to finalize in the Samsung.
The -R are most useful for copying from tape that is already edited the way you want. Be sure to finalize it.
The RAM can be used repeatedly, and can be protected but not finalized.
The EM-55 allows you to unprotect the disc and edit it.
To play a RAM you must have a RAM compatible machine. The good news is Sony makes a RAM DVD for computers.
Posted on Dec 24, 2014
  • 643 Answers
What kind of discs dvd-r, +r, +rw, Ram,??? Dvd-r are more univeral for playback. rw is usually cpu format.
Posted on Mar 24, 2011
The panasonic dmr e55 will burn a disc from my video camera and play on the dvd player but no other dvd player. and i read all the instructions step for step
Have you finalized the disk after recording? Are you using DVD-R disks? Also, I can replay my recorded DVRs on my portable DVD player, but not on a TV with a built-in DVD player. That one is just to finicky.
Nov 19, 2009 | Panasonic DMR-E55 DVD Recorder
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd recorder wont record or play
It is also possible that you are trying to record using an already used -R or an unformatted RAM disk.
Mar 07, 2009 | Panasonic DMR-E55 DVD Recorder
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Jan 15, 2008 | Panasonic (DMR-ES45VS)
Remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Oct 23, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Oct 13, 2007 | GoVideo Home Audio&Video: Go-Video DVD...
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-E55 DVD Recorder Logo
167 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
