Question about LG LHT734 System
How to adjust tone settings manually for my LG LHT743 DVD receiver? I have several preset settings but no Bass, trebal control
    Problem Solver:
  • 14 Answers
I did some research on this, but was unable to find out how to adjust bass and treble control individually. this is a link to the users manual (not sure if you have or not). You can download it if you like. I did, read through it, and didn't find anything to solve your issue. Unfortunately, this is a common setup for a lot of newer sound systems. Since they are digital, to achieve superior performance, they keep the settings digital and dont allow for fine tuning of the lower and upper frequencies (bass and treble).
http://www.retrevo.com/support/LG-LHT734-Home-Theater-Systems-manual/id/3126dj199/t/2/
I hope this helps.
JD
Posted on Mar 24, 2011
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I cant figure out how to set the sound, bass, treble, etc..
hi Rob, here is the user manual, http://www.clarion.com/us/en/MungoBlobs/779/346/DXZ665MP-ENG.pdf page 13 and 14(of the manual) tell you how to manual adjust bass, treble, fading, balance etcHope this helpsShona
Apr 10, 2012 | Clarion DXZ665MP CD Player
How to adjust tone on sony tv without obvious tone controls
If this TV has a working remote, and unless it is older than dirt, you should be able to access the audio adjustments by punching the menu or set-up button and selection audio - from which you should see a graphic equalizer of some description. Then adjust your bass there and return to viewing by again hitting the menu button. It's doubtful you can do any of that, or even that you should have to, from the set front.
Nov 09, 2017 | Sony Televison & Video
I can not figure out how to get to the settings for the trebal bass etc on the dual xdvd8180
on the top of your screen it will say radio dvd av1 av2 and set.
press set and then it should have another list across the top. you would then have to press audio .that should take you to the bass treble etc.
Jul 08, 2009 | Dual XDVD8180 Car Video Player
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
I can't figure out how to adjust the bass on the JVC KD-HDR30.
Hello hawk713, Like with many other JVC receivers, adjusting the bass is done from the "EQ" (equalizer) mode for one or all of 6 presets: ROCK, CLASSIC, JAZZ, HIP HOP, POPS, and USER. To adjust it, select the desired preset mode, use the left/right rocker (on volume control) to scroll to the desired frequency, 60, 150, 400, 1K, 2.4K, 6K, and 15K, and then turn the volume control up/down to set a level from -5 to +5. 60 and 150 adjusts the bass, 400, 1K, and 2.4K adjusts the midrange, and 6K and 15K adjusts the treble. Then you select whichever EQ setting sounds best with the particular music you're playing. Hope this helps.
Jun 06, 2009 | JVC KD-HDR30 CD Player
I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
Feb 26, 2009 | Proscan 32LA30Q Television
DENON 2308
IF YOU HAVE A MANUAL FOR YOUR DENON THE INSTRUCTIONS FOR ADJUSTING THE BASS AND TREBLE IS ON PAGE 40 UNDER TONE CONTROL IF NO MANUAL FOLLOW THIS LINK TO DENONS WEBSITE http://www.usa.denon.com/AVR-2308CI-OM-E_109.pdf
Nov 26, 2008 | Denon AVR-2307 Receiver
Reciver need to adjust bass or trebel
Hi Brent
hhmmmm, I searched through the manual to find this info for you. It appears that the tone adjustments are initiated by the "tone" button on the REMOTE. I could not find any reference to there being a button to do same on the front of the unit. Odd, but there you go.
  1. Use the tone key(on remote) to get "tone" up on the front of the unit.
  2. Then using the multi up-down keys, turn the "tone on".
  3. Once you have got to here, use the tone key to select "bass" or " treble"
  4. Using the multi up down keys, adjust the tone controls to your liking with the multi up down keys
you can download the manual from
http://www.retrevo.com/s/Kenwood-VR-60RS-Receivers-review-manual/id/480bh239/t/1-2/
Just enter your email address and away you go. Good Luck. A "FixYa" rating would be great for my time to research this for you.
regards
Graeme
Feb 16, 2008 | Audio Players & Recorders
LG LHT734 System Logo
306 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
