Question about Dremel Variable - Speed Multipro Rotary Tool 395
HOW TO USE A DREMEL TO NOTCH A 4 X 4 - Dremel Variable - Speed Multipro Rotary Tool 395
  • 10,865 Answers
Hello marty. Lay out the knotch in the post with a square and a pencil. Cut the lines to the proper depth with a saw and then use either the dremel tool or even a chisel and a hammer to remove the waste. Joe
Thanks for choosing Fixya!
Posted on Mar 24, 2011
How do I fix a Dremel 4200
I just came across this problem and could not find help online. Dremel wants me to send it to them. Their turn around time is 3 days but that doesn't count the 4 day ship to time nor the 4 day day ship back time.
I cut it off with another super cheap dremel type tool. I would have used a sander or bench grinder if necessary.
After I grinder down to just see the threads I put a flat head screwdriver in and pried it loose and then it twisted off easily.
I then realized what cause it. The plastic housing threads had slightly melted to the metal threads. Dremel bits get hot! The heat works it way to the shafts which in turn works it's way into the plastic.
The dremel can be used without this housing if you completely destroy it. I'm sure you will get by fine since you probably wanted to put an accessory on anyway. You can probably order a replacement in the meantime.
May 03, 2016 | Dremel Tools & Hardware - Others
How do i fine a scewdiver to fix my margaritavill, its has a scew in the bottem, that i have not seen befor..how i need to take the bottem off?
A photo would help. If it is what I am thinking of (what looks like a flat heat screw with a dimple in the middle of the slot) you can take an old, small flat head screwdriver and file a notch in the blade to make it work. A Dremel tool works good for making this notch.
Nov 17, 2014 | Food Mixers
Show me how to adjust the carburetor on a bolens bl110
Bolens trimmer sputters and stalls and only runs on half choke? Here's how to fix it.
Look on the top of the carburetor and you will see 2 black screws that are mostly round with a flat side recessed in the aluminum housing. They are flat on top and have no notches to insert a screwdriver. The trick is to turn these two screws 1/4 turn counterclockwise. I have a set of precision pliers and used the fine tipped needle nose to turn them.
The other option is to try and notch the top of them enough so you can use a flat blade screwdriver. You can grind down the surrounding aluminum with a Dremel tool so you can access them better.
You can see in the picture that I scratched across the top of the screws as a reference to see how far I was turning them.
Jun 28, 2014 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
How to adjust a gas weed eater
I used a Dremel cut wheel to notch both screw heads for a standard screw driver. Had to notch the protruding side covers around the screws on the carb that prevent access to the screws as well, be careful not to cut into carb or surrounding hardware, thus preventing damage to unit. It works like a champ after fine tuning carb don't even need to choke it for starting.
With the added ethanol in some gas now most carburetors need a little fine tuning or it won't run efficiently.
May 22, 2014 | Garden
The bits that came with my Dremel are not the correct size
dremel have a collet adaptor to cater for this problem. They are available from the dremel dealer or hardware store
Apr 01, 2013 | Alltrade Tools & Hardware - Others
I have a Bolens BL110 starts fine but dose'nt rev at all
Mar 17, 2013 | Garden
Dremel 4000 Wire Question
Look for a small notch behind the brass fitting that the brushes slide into.89fe048f-be52-4363-a092-c429f109d42a.jpg
Aug 30, 2012 | Dremel 4000 Series Variable Speed Rotary...
Have a 4"blade dremel small
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or Dremmel.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 11, 2010 | Dremel Garden
How to replace brushes?
On either side of the switch is a black disk with a notch small enough for a small screwdriver. Unscrew it and take it off to expose the spring. Gently pull the spring out and the brush should be attached. If you encounter resistance, then you may disconnect the spring from the brush. If this happens then push the spring back in and hope you catch the brush; if this does not work, then get creative or take the whole thing apart to get to it. After that, just put the new brushes in and recap.
Apr 24, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
126 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
