HP G61 NOTEBOOK PC BIOS BLINK ERROR CODE 2 BLACK SCREEN LED LIGHTS ABOVE NUM LOCK KEY AND LED LIGHTS TO LEFT OF CAPS LOCK KEY FLASH 2 BLINKS.NO MONITOR WHEN HOOKED UP TO AN EXTERNAL MONITOR.CD DISC DRIVE RUNS SOMEWHAT,FAN COMES ON FOR A MINUTE AT START UP,BUT NOTHING ON SCREEN,BLANK.HARD DRIVE LIGHT NOT ON,DOESNT MOVE.AMD WINDOWS 7 ULTIMATE OPERATING SYSTEM
    Master:
  • 344 Answers
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
Posted on Mar 24, 2011
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Hp g61 notebook pc bios blink error code 2 black screen led lights above num lock key and led lights to left of caps lock key flash 2 blinks.no monitor when hooked up to an external monitor.cd disc drive...
If screen and external monitor do not work then the issue lies with the video section of your laptop. The video chip is soldered onto mo bo and there is noway you can replace it if bad. Kiss your laptop sayonara, salvage the hard rive and memory and get yourself a new laptop that works. And avoid HP - their customer service is non existent after warranty runs out. They refer you to a forum or tell you to get another unit - an HP of course!
Sep 08, 2017 | Computers & Internet
When i turn on my hp the screen stays blank and there is no pic screen seems dead the lock a button is also flashing is this normal
hi,
nope this is not normal. I have a article included below from hp. read this and you will understand the problem and also some ways on how to fix it. The blinking lights is a code on where the system fail or what component that fails.
Hope this helps you.
Don't forget to rate me OK!
Thanks for using Fixya!
regards,
John
HP Black screen error codes
Support details
Error code explanations
The sections below provide some common explanations for each error code listed in the table above.
AC Adapter not connected or battery low charge
When the computer is on battery power only and the AC adapter is disconnected, if the Battery Power and Caps Lock / Number Lock LEDs do not glow, there is either a very low change or no charge in the battery. Connect the AC power adapter, verify that the battery power LED glows, allow the battery to charge for 15 - 30 minutes and then attempt to start the computer. If it starts, run the battery test and calibrate the battery. If it does not start, if possible, connect a replacement battery to verify that the battery is the problem.
If the computer does not start after charging the battery, remove the battery and connect the AC power supply. Verify that the battery power LED glows, and then attempt to start the computer. If the LED still does not glow, either the AC adapter has failed, or there is a bad connection between the adapter and the system board. If possible, connect a different AC power adapter to verify that the adapter is the problem, or contact HP for support which may require a service event.
showhide
If the battery light LED (which looks like a lightning bolt ) flashes, the battery has insufficient charge to start the computer. To resolve this error, try the following solutions.
Connect the notebook PC to AC power and attempt to start the computer again.
o
Check the AC adapter to confirm that all of the plugs are securely seated.
o
Determine if the power LED on the AC adapter is lit (if available) to verify that the computer is receiving AC power from the wall outlet.
If the computer operates on AC power correctly, charge the battery for thirty minutes to one hour and then restart the computer.
NOTE: Charging the battery for this length of time is called "trickle charging". Trickle charging is a continuous constant-current charge at a low rate, which recharges the battery slowly when it is in a deep discharge state. Deep discharge occurs when a battery is left unused for extended periods of time.
The computer processor (Blink code 1) has stopped functioning properly. Contact HP for assistance.
If a BIOS corruption error occurs (Blink code 2), you may not even notice the blink codes, because as soon as the computer recognizes the error, it restarts, attempts to recover the BIOS, and then restarts again. You may notice an extra-long startup process as a result, and a message indicating that the BIOS has been recovered may display on startup. If this occurs, update the BIOS on the computer. For more information, refer to the HP Notebook PCs - Locate and Install Updated BIOS, Drivers, and Software .
If you experience a memory failure (Blink code 3), follow the guide in the table below.
If Using Original Memory If New Memory Is Added
Reseat the memory.
If reseating the memory does not resolve the problem, try replacing the memory with new memory. Reseat the memory.
If you continue to experience this error code after reseating the memory, the problem may be with the memory itself. Take the new memory out of the computer, put the original memory back into the computer, and then retest it.
If you do not feel comfortable reseating the memory yourself, take the computer to a computer retailer and ask them to reseat it for you.
NOTE: Some memory module errors may allow the computer to start but will then cause the computer to restart and display a blinking error code.
If you experience a graphics controller failure (Blink code 4), contact HP for assistance.
A general system board failure (Blink code 5) is the failure of a component not covered by the other LED error codes. Contact HP for assistance.
The BIOS authentication error (Blink code 6) is extremely rare. It is the result of a discrepancy between the BIOS and the hardware that is installed on the computer. This error occurs when the BIOS cannot authenticate signatures from the hardware on the system. The purpose of the BIOS authentication is to be sure that no one has tampered with the BIOS on the computer.
If a BIOS authentication failure occurs, the computer automatically performs a BIOS recovery. If the computer does not automatically recover the BIOS, manually perform a BIOS recovery. To manually perform a BIOS recovery, press all four arrow keys at the same time to cause the BIOS to go to the EFI partition to find and recover the current BIOS.
Jan 17, 2011 | HP Compaq nc6220 Notebook
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Computers & Internet Logo
2,864 people viewed this question
David Payne
David Payne
