Question about Gestetner DSm660 Copier
Set IP address to printer dsm660 - Gestetner DSm660 Copier
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Look my friend first go to system sitting in press on north left and choose interface sitting and yo will see ip press on it and change
Posted on Mar 25, 2011
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
We are trying to download the drivers for a network but it is asking for the IP address IPv4 and we don't have it. Could you provide it.
well check your printer machine IP address...just like a computer printer machine have their own IP.then use the IP of you printer...
Jul 21, 2011 | Panasonic Workio DP-190 Multifunction...
How to set IP address to the printer
I think you mean to set a Static IP address.
Go to user tools
System settings
Interface
Touch the tab IPv4 and specify the IP and Sub-net Mask
Press ok to save that settings and press the tab bellow to set the Gateway.
Press ok and your configuration is set.
If you have any doubt reply to me.
Mar 24, 2011 | Gestetner DSm660 Copier
Hi Guys I hae set up IP address and other network related setting. I can't ping to the printer. Not able to get automatic IP address from the DHCP no ping.
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Oct 23, 2010 | Epson TM-U220 Matrix Printer
Hp officejet 7210. When router resets, I loose my printer connection.
IS this printer wired LAN to your router? If so, look in the settings to your printer and check the IP address.
Now in the settings menu, it should have an option for you to set DLNA or manual. Set to manual. Enter the same IP address the machine originally had. If you could not find what ip address your printer had, in windows startmenu find run or command prompt and type ipconfig all.
Find the ip address for your computer. Add 10 to it. For example, if it is 192.168.0.2 than give your printer 192.168.0.12 If it asks for a subnet mask use 255.255.255.0
I believe the problem you are having is that every time your router resets it gives your printer a different ip address (dynamic IP), so your printer driver software can no longer find it. You need to use a static ip address (manually giving the printer an ip address) so it never changes and the driver can always find it.
Sep 24, 2010 | HP 7210 OfficeJet All-In-One Printer
How to give ip address in to printer settings?
check with your system admin.what IP add.
follow your printer manual.
Oct 06, 2009 | HP LaserJet 3055 All-In-One Printer
No IP address was set
Turn off DCHP after setting the IP address
Sep 21, 2009 | Toshiba E-Studio167 Copier
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
HP Officejet printer
i assume that your printer is connected to a network. if so, it could be that the printer is set to use dhcp for the ip address. and if that's the case, it's better to set the printer to use static ip address since there would come a time that the dhcp server (a router most of the time) would provide another ip addresses to all the devices connected to it. that could be the reason why you are getting a "no connection" message (disconnecting and reconnecting it at times would solve the problem temporarily).
here are the steps on how to set static ip on the printer using a windows computer.(Note: the installation cd can automatically assign a static IP address as long as the printer does not obtain a dynamic (dhcp) address)
- boot up your computer the normal way so it'll get an ip address from your dhcp server
- then turn off your dhcp server so that the printer will not get any ip address via dhcp
- reset the printer to set its factory default configuration (with no dhcp address)
* unplug the printer from the power
* plug the power cord back in while holding in the printer’s
report button (it will try to find a dhcp server; after about three
minutes of no dhcp response, the printer will default to a static ip address of 192.0.0.192
- then print a configuration page to confirm that the ip address of the printer is set to 192.0.0.192
- then press the report button (wait until IP address is 192.0.0.192 before proceeding. if it remains set to 0.0.0.0, check the network cable connection to the printer and to the network is secure. If some other address appears repeat steps 3 and 4 until the default address appears
- you can now start the software installation cd
*during the installtion, follow these steps:
- select the model of the printer that you are using which is hp officejet before clicking on "next"
- then select "do network settings for me, then press "next
*follow the instructions on the remaining install screens
- the software will pick an ip address in the private 169.254.x.x range (not available on the open Internet) and permanently assign it to the printer. it will also set up a static route to that address in the computer’s printer configuration
- turn the dhcp server back on by turning on the dhcp server by
connecting your cable/dsl modem or dhcp to the network. because the hp now has a permanent static ip address, it will
no longer try to use dhcp server to get an address
- install the software on the other computers on the network who will be using the printer. the installation software will discover the hp printer at the 169.254.x.x address, and will add the static IP address in each computer’s printer configuration
Note: if the installation cd will permit you to change th private ip address from 169.24.x.x, it's better to set it on the same range as of the ip address given by your dhcp server (for example your dhcp server provides ip addresses starting from 192.168.1.100-192.168.1.250, set the printer's ip address to 192.168.1.59-below or any ip address that will not compromise any ip addresses that were already being used by your other devices)
hope this'll help you but if you'll have other concerns just ask me.
ciao!
Jun 28, 2008 | Computers & Internet
Gestetner DSm660 Copier Logo
91 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
