Question about Labtec LCS 2408 Computer Speakers
I have a Labtec 2408 speaker which I picked up second hand. There was no transformer with it. I know it is 15 volts DC but there's no indication of the wattage needed. Also, I would like to use this on my MacG4 with a set of Harmon/Kardon speakers. Suggestions??
    Top Expert:
  • Labtec Master
  • 75,581 Answers
Hello
A [13.5V 6Amps AC] transformer is sufficient to drive its internal circuits. OK.
Posted on Mar 24, 2011
How volt transformer for AOpen spekers?
If it is the transformer, it should be a DC output. Look where it connects, it will tell you what voltage you need. Use a volt meter to see if you are getting that from your "transformer". If so the amp in the speaker is probably blown, if not you need a new DC power supply with the correct voltage. If the replacement ma is higher that will not hurt, The information should also be on the "transformer".
May 31, 2016 | AOpen Audio Players & Recorders
Power requirements required are 6 volts dc at what amperage?
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
Nov 29, 2013 | Labtec LCS 150 Computer Speakers
I've had a Labtec LCS 2408 for several years, and been happy with it. However in the last few months, the volume control got noisy, worked intermittantly, and then quit altogether. How can I take...
Well if you want to try and can't get it opened up just take the knobs off and vacuum it out, then if you have some compressed air blow it out, and if you are really protestant spray a squirt or two of WD-40 in there. Not a bunch just a little bit, sometimes if it has residue built up in there the WD-40 will break it down. Good luck, if determined to take apart make sure you pull any rubber pads off the bottom and remove those screws too, it will most like snap together pretty tight since it's a speaker and they didn't want it rattling.
May 11, 2011 | Labtec LCS 2408 Computer Speakers
I have no power supply cord for my labtec lcs-1030 speakers- what do i replace it with? i cannot find specs for it anywhere online
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Labtec LCS 1030 Computer Speakers
Can I connect a Labtec Model AD-SS-3 to my laptop?
This model of AC adapter puts out 14.4 Volts of DC current, at 1.0 Ampere.
I doubt that 1.0 Ampere is enough amperage to run your computer, or to recharge your computer's battery.
Look on eBay for the model-number of the original AC adapter.
You might find one from the manufacturer of your computer,
or you could find something that will be compatible in voltage/amperage.
Aug 19, 2010 | Labtec LCS 2414 Computer Speakers
Will not adjust weight
Plug the indicated end of the Transformer into the Rear Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformer when using the resistance system.
Then, press and hold the NEXT button and the motorize resistance + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, and then press the MOTORIZED RESISTANCE + button; this will start the recalibration process. This may take a few seconds as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120-volt outlet.
If you cannot hear the motor reset it self or cannot see display then with multi meter check DC voltage if not replace transformer , if you have DC voltage you will need to remove the cover locate the motor assembly disconnect the assembly from the upper electronics. Then apply a 12v DC voltage to the motor and see if it engages easily if not then replace motor. If motor functions properly replace connector back on the motor and use a multi meter connect it to motor and plug in the transformer and you should see DC voltage going to motor if not replace upper console.
Jun 01, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
AVS 500 subwoofer speaker
If you have a digital tester just select DC voltage then connect the positive leads of the digital tester to any of the wire coming out of the 18V adapter (WARNING do not connect to the wire connected to the main) and then the other lead of the digital tester which is the negative connected to the other wire of the 18V adaptor. If in the screen of the digital adapter reads a negative value, then it indicates that the other wire is the negative and the other is positive. Otherwise if the tester reads a positive value then your tester's leads have got the right connection.
P.S. please rate me.
Jun 10, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
Labtec LCS 2408 Computer Speakers Logo
82 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
