Question about Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit
I purchased brushes for my 12 volt dewalt drill yesterday at the Dewalt warranty store in Denver. Today I took the housing off the drill and it does not have the same type of brushes in it as the counterman sold me. (I took the drill into the store so I would get the correct parts.) are they different for the 12 volt than the 18 volt? these look like the ones for a 18 volt. The production date on the drill housing is 200602-49.
    Problem Solver:
  • 17 Answers
Brushes over time will wear down so comparing from the old to new will not look the same. If 18V brushes fit into the your drill then it should be fine.
Posted on Apr 06, 2011
Dewalt impact drill will only beep, lights go on, just took this drill out of the box today.
Did the light on the charger indicate that it was charging? (Most also have a "replace battery" or similar light.)
If so, and the drill keeps beeping...since it's new don't bother monkeying with it. Just take it back to the store and have them replace it. Dealing with a warranty repair will leave you without a tool for some length of time.
Dec 25, 2014 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
Dewalt 18vxrp stopped working. Any suggestions???
Knock the back end against something. Or shake the drill and if it sputters, it could be a loose wire, or more likely worn brushes. If that doesn't do anything, open the case and check with a volt meter if you are getting any current past the switch (ie hold the terminals from the volt meter onto the brushes or onto the leads coming out of the top of the switch.)
If you get a reading of 19V to a couple volts less, then you're switch is most likely okay. Check for worn brushes. Or a motor replacement might be necessary. (Yes it's easy to do)
Apr 21, 2012 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
How to replace brushes in dewalt dw959
Simply Google "how to replace 18v dewalt drill brushes"
You will get three youtube videos on how to do it right at the top of the page...
heatman101
Sep 08, 2010 | Dewalt ; 18v 1/2" Compact Drill Driver...
I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Dec 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
The chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
Oct 30, 2009 | Dewalt 18 Volt Compact Drill Kit
14.4v dewalt xr2 drill
Some cordless Dewalt drills do not have open motors allowing access to the brushes. However there are a few styles that do.
If you want to check, open your drill. Remove the screws from the housing. Then remove half of the housing. You can see the motor at the back of the tool. If there are vents at the back of the motor you may be able to see the brushes the removable type are connected to a gray or tan piece of plastic mounted at the back of the motor.
If the brushes are from a removable style you can purchase a brush set. If they are hidden in the motor. You will have to change the whole motor.
You can check the Dewalt Service Net web site to find out.
Apr 20, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Logo
208 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
