Question about Intel ASRock G31M-S M/board - Intel G31+ICH7, 1600(oc) MHz FSB, Dual DDR2 800, PCIE, int VGA, SATAII, 6-Ch... Motherboard
No supply coming - Intel ASRock G31M-S M/board - Intel G31+ICH7, 1600(oc) MHz FSB, Dual DDR2 800, PCIE, int VGA, SATAII, 6-Ch... Motherboard
  • 961 Answers
Your informatio above is correct You also have Intel GMA310 video chipset and Realtek ALC662 for sound You also have socket, LGA 775. I'm not suer what you're looking for but, you could try;
http://downloadcenter.intel.com/
This is Intel's donload site where you can have them scan your system, using the "Run Intel Driver Update Utility", which will scan your system and advise you of any Intel updates, or you could choose "find downloads by product name, and select which one you'd like to update.
You could also try;
http://www.asrock.com.tw/MB/download.asp?Model=G31M-S
This is Asrock's download site. I have entered your info and you can get driver and Bios updates.
If you are looking for somethig else let me know at "add a comment"
Dave
Posted on Mar 24, 2011
    Genius:
  • 1,126 Answers
You ned to check first the power supply and make sure it is putting out the voltages that it should be.
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Steady green light in the back--have reset the memory cards and checked all connections. I took cover off plugged power in and the green light comes on steady once again but th e fan doestn run and the...
replace your power supply you have lost your 12 volt supply coming from your power supply
but you have your other power supply voltages still working
Sep 30, 2013 | HP Computers & Internet
The power supply light on the board comes on but when i hit power button cpu fan comes on for a second and doesnt come on
The first thing I would suspect here is the power supply itself.
Unless you have a power supply tester, thought, it's rather difficult to test it. I usually replace the power supply in situations like this and all is well.
Jan 11, 2010 | Dell Dimension 4600 PC Desktop
Fans do not come on when plug power cord in
You can get the fan from any other power supply. Try a computer repair shop.
Please don't forget to rate if the answer helps
Oct 14, 2009 | Alienware PC Systems Alienware True 420...
42" Vizio Power supply board output voltage?
The next thing I would check out is the power supply for the screen. Most manufactures call it a Backlight Inverter Board. If a part does go bad on this board, it would also cause the stand by mode or protection mode.
Jul 30, 2009 | Vizio L32 32 in. LCD HDTV
My tower will not turn on I don't know what could be wrong with it under the power supply it's red. I only had it for a few month's and I tried everything.
does the power supply come on? theres a little switch on the back of the power supply it says 110 or 220. make sure its on 110. Also the red is coming from a light on the power supply or on the boards below the powersupply?
Apr 15, 2009 | Computers & Internet
An error #704 message keeps coming up and telling me to check supply, but as far as i can tell everything is loaded correctly. any ideas?
Check your supply settings. Die cut or black mark?
It's also possible you have a bad/broken/dirty supply sensor. The supply sensor is black and is located on the adjustable supply guides. These guides are what you first feed the supplies thru as they come off of the roll. Opposite of the small black latch you move to adjust for supply width.
Mar 01, 2009 | Monarch Paxar? 9855 Label Printer
Power supply not coming on
first of all you need to connected the power supply connector, processor connector, hdd connector, cd rom connector.
check it
Jan 21, 2009 | ASUS A8N-SLI Premium Motherboard
Computer doesn't come on.
Easy check is: power the system off. Unplug the power supply from the outlet. Hold the power on button in for at least 10 seconds. Remove the CMOS battery. Reconnect the power supply to power. Attempt to power up. See what happens. If it comes up and asks for you to set config, power down, unplug the power supply and hold the power on button for 10 secs. Replace the CMOS battery with a new one (CR2032 button battery...about $5 for 2 in the Wal-Mart photo dept) and power on. The reason for the repetition is to reset the BIOS.
Sep 08, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Intel ASRock G31M-S M/board - Intel G31+ICH7, 1600(oc) MHz FSB, Dual DDR2 800, PCIE, int VGA, SATAII, 6-Ch... Motherboard Logo
323 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
