Question about Bugaboo Frog Stroller
My bugaboo wheeled board needs to be re attached but have lost the instructions can you please tell me how i can re attach this many thanks
  • Buggabood Aug 10, 2008
    Ditto. Did anyone have a solution for this?
  • 13 Answers
Leave the (bassinet or seat) on, then flip the stroller forward, the big wheels have to be in the air. put on the clips make sure
you put the right on the right and the left on the left push them until they cover the silver screws. then put the wheel board on
huging the bar if not it will not go in start from the very bottom. And once its on don't forget to put the elastic with the velcro on.
the velcro goes on the bar right above the wheelboard. this will help you keep it up when your not using it.
Hope this helped.
Nathalie
bugabooexperts@yahoo.com
Posted on Dec 07, 2008
Can't get wheel off bugaboo bee (to replace it)
Screw the inner bolt back in but leave sticking up by a 1/4 inch then use a block of wood and a hammer to tap inner bolt to force the outer bolt out.
Jan 30, 2012 | Bugaboo Bee Stroller
Cannot attach wheeled board to Bugaboo Chamelean with Bassinet
In previous posts I've said the Bugaboo gets an A for design, The wheeled board gets a B-. Your problem is you're trying to fit it with all four wheels still on the ground. Put to on it's side and you can the rotate the board further around to fit the clips. Go here to get Bugaboo's instructions For those yet to buy a wheeled board click on my name or picture and click on Tips. There is a better alternative to the Bugaboo board.
Nov 27, 2010 | Bugaboo Cameleon Jogger
How to attach the wheeled board to the bugaboo cameleon
If you visit www.bugaboo.com you will be able to download the user manual in .pdf form.
Hope this helps.
Mar 14, 2010 | Bugaboo Cameleon Jogger
Spare Parts for Bugaboo Wheeled Board
For Bugaboo spare parts, the best way is to contact Bugaboo direct (www.bugaboo.com) or a local Bugaboo stockist who should be able to order in the spare part for you.
Sep 15, 2009 | Baby Gear
Bugaboo frog and wheeled board not fitting??
Had exactly same experience today. I emailed Bugaboo (via website) and got a reply the same day.
I attached the clips the wrong way round. The picture in the manual is not very clear....The little 'roofs' have to face each other and than you are able to push the clips further over the axle. The slot of the clip fits over where the small wheels comes in on the bar.
Hope this helps.
Jul 26, 2009 | Bugaboo Frog Stroller
Bugaboo Frog Wheel Board
i'm sure you have solved this already, but yes, there should be two pieces that attach to the back axle that the board slides onto to attach it to the stroller. It wont work without these parts. The person you bought them from probably still has these parts attached to their stroller.
Mar 31, 2009 | Bugaboo Cameleon Jogger
Need to fix a Bugaboo Frog wheel
just order new wheels from bugaboo. They cost about $30 bucks each or contact a local retailer to order you some wheels.
Mar 30, 2009 | Bugaboo Frog Stroller
How do you remove a maxi cosi attachment for a bugaboo?
you press the white part on the adaptors and pull upwards
Dec 28, 2008 | Bugaboo Cameleon Jogger
Bugaboo gecko tire flat and tube no longer attached to wheel
First try pushing the valve out while your pumping with bugaboo pump. If it blew out need to call bugaboo you have a two year warranty and they will send you a inner tube or a new wheel.
Tel# 1-800-460-2922
nathalie
Dec 04, 2008 | Bugaboo Cameleon Jogger
I'm trying to install the wheeled board on the bugaboo. Have followed the instructions - but there seems to be a floor as the wheeled board is too wide for the clips its about 5mm too large. Anyone else...
We have installed the board and have found that the fitting is quite tight. I have noticed that the clips slide slightly when turning the bugaboo over to fit the board, so you need to keep pushing the clips back into place....hope it helps! As an aside, we have bought the seat attachment (not sold/made by bugaboo) which has been fabulous...it has certainly helped when out with the two children and has been the envy of lots of other little ones!
Aug 09, 2008 | Bugaboo Cameleon Jogger
Bugaboo Frog Stroller Logo
3,120 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
