Question about GPS
WHAT IS EPS? - GPS
  • 206 Answers
The NHS Electronic Prescription Service (EPS) is part of the NHS National Programme for IT of the National Health Service in England. It will enable the electronic transfer of medical prescriptions from doctors (or other prescribers) to pharmacies and other dispensers and electronic notification to the reimbursement agency, NHS Prescription Services.
The project is to be delivered in two releases:
  • Release 1 retains the paper prescription and adds a barcode to it allowing pharmacy to access a centrally held copy of the prescription[. This phase has been extensively deployed among general practitioner systems and slightly less so in pharmacy systems.
  • In Release 2 an electronic prescription can be used where the patient nominates a pharmacy. This could be sent electronically although a paper token may be printed off also.
Posted on Mar 24, 2011
2014 dodge ram 1500 eps failure how do I fix or better yet how do I get my power steering to work its a electric and I don't under stand is there fluid if so where does it go
I have no wiring diagram on 2014 eps, so I looked at 2013, hope they are the same?
https://s26.postimg.org/lgarr71eh/eps.jpg
Click on the link.
Check those two fuses, not only check the fuse, use a test light and check voltage on fuse circuits. The component at lower left is eps module. As you can see black wire is ground, check that also.
Check for applicable trouble codes? My info for 2013 no electrical component, eps, can be serviced separately. I definitely do some testing. If you have to replace eps motor and module, I don't the cost of the fix? I don't know if 013 and 14 are the same? Just trying to help.
Aug 28, 2017 | Dodge Cars & Trucks
The EPS light has come on my dashboard and the steering has become very heavy. what does this mean
The electronic power steering (EPS) Warning Light is located on the instrument panel. This light illuminates when the EPS is malfunctioning. When this light is lit, your steering may be a little heavier, and you should schedule an inspection as soon as possible. Tip The EPS Warning Light briefly illuminates when the car is first turned on. The light is only a problem if it stays lit for an extended period.
Jul 04, 2017 | Cars & Trucks
Pontiac 2009. Would the eps fuse missing stop the car from starting
The EPS fuse is for the electric power steering. The EPS fuse is usually a 60 amp fuse. It may be a safety kill switch associated with not having a fuse in place. It is not usually safe to drive a car without the steering working properly. GM has had a huge recall on the EPS system, including some 2009 models.
Oct 10, 2016 | 2009 Pontiac G6 GXP
WHERE IS THE FUSE FOR MY POWER STEERING IN MY 2006 CHEVY HHR LOCATED?
You vehicle has two fuse's ! one in the underhood fuse box EPS/STR WHLCNTRL an it is a 60 amp . An there is one in the BCM fuse center - EPS 2amp fuse ! do you know what an where the BCM is ? The BCM - body control module !
Body Control Module (BCM) location
Under the I/P below the radio on the right side of the center console .19
EPS/STR WHL CNTRL
2A
Electronic Power Steering (EPS) Column Assembly and Inflatable Restraint Steering Wheel Module Coil
Aug 05, 2015 | 2006 Chevrolet HHR
Where is the power steering pump located?
ELECTRIC POWER STEERING (EPS)
The TSX uses Electric Power Steering (EPS) which regulates steering via a computer-actuated electric motor. With the computer-controlled system, advanced algorithms built into the operating software allow for continuous fine-tuning of the steering assist forces so that minimal force is required at low speeds- such as when parking or maneuvering. Conversely, progressively higher steering effort is generated at higher speeds (such as when driving on the freeway) to deliver a sport-minded driving experience.
The EPS system found in the TSX is an evolution of an earlier EPS system found on the Acura NSX supercar. Its key features and advantages include:
  • The EPS system reduces the steering effort at low speeds, improving agility and ease of effort when parking or maneuvering in tight areas
  • Rigidity of the steering mount is higher, which allows a more precise and "connected" feel during high-speed maneuvers (such as during lane changes or when on winding mountain roads)
  • The EPS steering assist incorporates computer algorithms based on vehicle speed rather than engine speed, allowing TSX engineers the flexibility of tailoring the steering feel to match actual driving conditions- especially high-speed driving. The EPS steering algorithms incorporate steering assist changes for every 0.6 mph.
  • The EPS system is different (and uniquely tuned) for each of the TSX models: 2.4L I-4 sedan, 3.5L V-6 sedan, and the new Sport Wagon.
  • EPS employs a sporty, 13.5:1 steering ratio which further improves performance driving agility
  • In its evolution from the original NSX system, the TSX's EPS system uses a significantly more powerful electric motor teamed with a far more sophisticated microprocessor
  • By eliminating the conventional power steering pump assembly, EPS uses less engine power which improves acceleration and fuel efficiency
it is an electric pump without a pulley or belt or fluid apparently
Aug 09, 2014 | 2011 Acura TSX
Eps light coming on
1. disconnect the battery both terminals.
2.Look for EPS control module on front passanger deck below dashboard,disconnect the cable connector
3, spray both EPS and cable connector with contact cleaner aerosol.immediately plug in back.
4. Right above EPS module there are Air Con piping make sure the condensate water do not dripped onto EPS module by covering it with plastic sheet.
5. Spray all cables to battery terminal with contact cleaner and connect it back.
6. Start your engine .
In case it still dont work ,you have to look further into EPS motor.
Hope it will solve your problem at least it work for me.
Oct 29, 2013 | 2006 Mitsubishi Colt
I have a 06 saturn ion 3 when im driving the power stearing light will come on and the wheel will tighten up but if I kill the car and start it back up its fine , then it will do it again so I do the same...
What pump are you checking an fluid level ? Your vehicle has electric power steering an has no pump or fluid .
Your best bet , take it to a GM dealer , had recall on parts of the EPS , electric power steering (EPS) system .
The electric power steering (EPS) system reduces the amount of effort needed to steer the vehicle. The system uses the body control module (BCM), power steering control module (PSCM), torque sensor, discrete battery voltage supply circuit, EPS motor, serial data bus, and the instrument panel cluster (IPC) message center to perform the system functions. The PSCM, torque sensor, not the EPS motor are serviced separately from each other or from the steering column. Any EPS components diagnosed to be malfunctioning requires replacement of the steering column assembly, also known as the EPS assembly.
Jan 01, 2018 | 2004 Saturn ION
Where is a power steering pump located on a 4 cylinder chevy cobalt ls
Your Cobalt is not equiooed with a Power Steering Pump. It has electric power steering. See the description below.
Power Steering - System Description and Operation
Nov 20, 2009 | 2005 Chevrolet Cobalt
Gear shift and EPS problem
my car is Honda City 2005, EPS light get on and steering get hard like truk, I have visited Honda Service Center where they set the software by using their computer. after 2 or 3 weeks it again occure and same parctice is done at service center. Is there any permenent solution for this EPS problem
Nov 01, 2009 | 2006 Honda Civic Hybrid
GPS Logo
349 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
