Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It goes to unbalanced load all the time. - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Brigadier General:
  • 3,513 Answers
Hi
Unbalanced load is caused more by an under loaded machine than an overloaded machine. If the machine keeps going to unbalanced load then there must be some factors behind it:-
An unregulated motor...The module that controls the motor needs adjusting or replacing or the motor needs calibrating, because the speed is finely regulated to balance the wash load when the machine goes into spin. After the machine has tumbled it goes into distribution mode, and this is where most of the problems occur. The drum has to build its speed from tumble (35-55 rpm) to distribution speed (83 rpm). If this does not happen gradually, the clothes will gather at one side of the drum and create an out of balance load. Hotpoint and Service (older carbon brush) motors can be adjusted by turning the brass calibrating ring on the tacho assembly attached to the back of the motor. Otherwise you need to take the control board to be repaired, re-calibrated or replaced.
Faulty suspension...There are two common types of suspension, a spring and friction plate type and a shock absorber type. The first one suffers from the friction plates becoming shiny and not gripping properly. This can be cured by either replacing the friction pads, or simply sanding down the surfaces of the pads to roughen them. The shock absorber type can suffer from broken legs, or loss of oil in the dampers. Either case would cause the tub of the washer to be loose and free to move around inside the cabinet.
Loose components...Any component from the motor to the concrete block at the top or bottom of the machine can become loose and cause banging. This requires visual inspection and repair.
Drum Bearings or mountings...Bearing faults are usually indicated by a rumbling sound which gets louder with time. Drum mountings are signified by a loose drum relative to the outer tub.
Motor bearings...Motor bearing faults are quite rare, but can be identified by removing the belt and manually turning the motor. Faulty bearings will make the motor harder to turn or noisy when it is turned. Usually this is caused by over tightening the belt, and the cure depends on which make of machine. Some machines have replaceable bearings, some need the armature replacing, and a few need to have the motor replaced as a whole unit.
Also check the bellow links to have a detailed idea related to your issue:-
http://www.washerhelp.co.uk/usage.html#cl_q2
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 24, 2011
Unbalanced load at nearly every spins cycle ,move clothes around until it spins
Is it a front load or top load? Do you have the make and model?
Jan 26, 2015 | Washing Machines
Maytag top loading washer goes straight to agitation, won't fill with water.
you may find that the water sensor is not working as it should, unplug the machine take the back off locate the small 5mm pipe going upwards take it off and blow gently into it you should hear a click and one when you release the air, if so then the place you took it from is blocked, clean it out with a pipe cleaner or metal rod replace the pipe and rear panel and run the machine again, try to make Shure that you always fill the machine to its recommended load to prevent unbalanced loads eric
Jan 11, 2018 | Maytag Washing Machines
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
My washer's digital time screen changes from the time remaining to a symbol that looks like "UL".
This error code indicates that an unbalanced load is detected.
Click the following to learn more about unbalanced loads in the BravosTM washers. The example is for an impeller washer but is applicable to washers with agitators.
Is the wash load balanced?
If the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
Is the washer level? Does the washer rock when pushed against the corners?
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened. See the Installation Instructions for details.
To remove the error display, press Power/Cancel or Pause/Cancel once.
Jan 02, 2011 | Maytag Bravos MTW6600T Top Load Washer
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
My PAVT920AWW won't spin hard enough to get all the water out
I have had teh same problem. I calledin the Maytag service and they did replace something out of goodwill but the technician told me that the load balance sensor is sensitive. If your load is unbalanced then the machine will spin slowly so it does not walk across the floor. With larger loads the wieght will make the machine bang against the sides and walk.
The solution is quite simple. Make sure the load is balanced. The agitator has a way of unbalancing a load from time to time so you need to do this manually. It is a very rare occurance and it is best to make sure your load goes into the machine balanced first.
Dec 19, 2007 | Maytag Performa PAV2200
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
