Question about Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422
Where the coils inside are soldered together, we are seeing cracking or peeling. Should we be worried?
    Champion:
  • 239 Answers
These are painted with a silver paint that falls off over time, this is normal and not harmful. It will work just fine and be okay. The next time you shut it off to defrost it, you can clean the peeling paint off.
Kelly
Posted on Mar 24, 2011
The outer plastic coating around frigidaire freezer thermostat has scratched off slightly is it dangerous to continue using freezer
That's just a beauty factor (mostly)...
Almost immediately peeled off of my kitchen-aid...
Insise... No problem.
I was told if water IS NOT FROSTING up on it... It will be fine.
If water IS frosting... OUTSIDE THE REFRIGERATOR....
the dripping can create lots of issues.
Place clean sheet of typing paper... just like checking those valves under the sink. Wait a few days.. check THAT paper.
No drops = everything is great.
Drops means you need to put some decent insulating
wrap
around the tubing to keep MOIST AIR from direct contact..
ELSE ... don't worry about inside refrigerator frost. Designed to handle & drain away water .
(my opinion... NO problem (I'm pretty vigilant about my wife's intake ... keeping toxins to a low roar (she's a keeper)))...
The brazing and tubing materials have not been TOXIC since lead piping days (decades ... wrong... generations ago)...
Good to be thoughtful about these things!!
Mar 29, 2016 | Frigidaire FVE4870A Freezer
Danby upright freezer plugged in a few hours ago, but coils on back are hot
If you are talking about the black condenser coli on the back of the fridge it is hot because the refrigerant is pulling all of the heat out of the fridge and trying to deposit it outside of the box. This is called hot box pull down. When the temperature inside the fridge comes down and you have product in it the coil on the back will become much cooler during operation. So if you are wondering it is nothing to be worried about, perfectly normal.
Aug 29, 2014 | Danby 10.4 cu. ft. / 294 liter Upright...
HOW DO I REPACE D00R SEAL
To replace your seal you'll have to remove the screws around the perimeter of the door's inner panel. Once all the screws are off separate the inner panel from the old seal and peel the seal away. It should peel away easily- if not use a Putty Knife to remove it.
Now take your new seal and "soften" it up a little by placing it in hot water for 10 minutes or so. It'll make it easier to place back in the correct position around the door since the seal was probably all twisted up and sharply folded doing shipping/storage.
Now simply lay it back in the same position the old seal was making sure there are no folds, creases or cuts in the seal. It must lay flat or it will leak all over again. Note: there is a sealant that you may want to get that's specially made for these seals to guaranty the seal gaps are filled and the seal stays in place. I use "Kitchen and Tub" Caulk when I don't have any refrigerator caulk available.
Now reassemble the door inner panel, your new seal, and the outer door all together with the screws you previously removed and you're all done.
If you need more info an excellent source is "Appliance Parts Pro". http://www.appliancepartspros.com/parts-for-frigidaire-ffu14k0dw0.html
Click on your Seal (item #1) and see the comments below that other customers asked.
Hope this helps.
Jun 27, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How do you know your Bosch Fridge Freezer needs defrosting?
Most home refrigerators share the same cooling coil for both compartments so in order to defrost the freezer that coil has to be disabled by pulling the plug. You havent mentioned the brand of refrigerator that you own but i am guessing that you have an automatic defrost. Can you hear a fan running inside the freezer compartment when the door is closed and the compressor in the back is running? If so your freezer will automatically defrost. The ice you probably see collects on the shelving or inside walls. Generally you can take the plastic handle of a screwdriver and gently tap the ice to get it to crack and fall off. Take care not to hit cold plastic parts or panels, they may crack or break. Otherwise I would get the model of the refrigerator and go to the manufacturers web site and post your question to get a positive answer. Good luck!
Jun 02, 2012 | Bosch Freezers
Side of freezer seems warm
Hi!!
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
Good Luck!!
Aug 03, 2010 | Woods 247 cu. ft. Upright Freezer FU25
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Power signal light is flickering
If the unit is still working, and the power light is flickering, don't worry about it. I've seen this very often where the small, rectangular power light flickers and there is absolutely nothing wrong with the unit. It's just the light going bad. It will probably, eventually go out all together. Again, as long as it's working and keeping temp. don't worry.
Dec 30, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Coil is broken. can it be soldered together?
Good day,
As a rule copper/steel yes. Aluminum no. However, if aluminum, wait a while, some guy may be weaving magic out there as I post this.
Small holes can be epoxied, but your describing a complete break.
2 brass unions and a new section of pipe might be made to work, but the ferrules in the union are copper, and copper and aluminum don't like each other, eventually leading to failure.
Nov 04, 2009 | Frigidaire Freezer FFU1212D
Kolpak - Polarpak - door left open all night, might be broken
check to see if the evaporator coil is frozen up, if so you can defrost with hot water.be sure to turn power off and not spray directly into fans.
Mar 17, 2009 | Kolpak Commercial Freezer Polar-Pak®...
Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422 Logo
103 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
