I have a compac presario cq60, I've recently got a brand new charger and battery both from hp as they both needed replacing. I've put the new battery in and plugged the charger in but I noticed that the light on the laptop next to where the charger plugs in, is flickering so I turned it on and the battery icon on screen keeps flickin from charging to not charging really quickly. I really don't know what to do next. Thankyou
  • 112 Answers
First thing to check is that the battery is inserted properly. Take the battery out, make sure there's nothing on the contacts, and then put it back in. The problem could also be that the charging jack on your laptop is loose. If you hold the charging cable plug in the laptop with a little (not a lot) force, or push it a little to the front or back, does it stay charging? If it does then the jack is loose. Your temporary fix is to hold it the way you did while testing to see if it was the problem. Be aware, this fix is strictly temporary, eventually the jack will get loose enough and not make contact at all. Consider calling Compaq customer service and checking to see if it's covered by warranty.
Posted on Mar 24, 2011
Persario/HP charger scam
Remove the battery before you plug in the charger/adapter and see what it will do. It can't recognize a battery mode if there is no battery. Maybe the charger you are using is not appropriate: different voltage, wrong polarity, the tip is not in contact with the plug terminals, or the circuit is not closed to allow the passage of current.
Rocketfish, Targus , and a few others, manufacture universal chargers that work with may laptop makes and models.
Mar 30, 2014 | HP Compaq Presario CQ60-249US Notebook
Charging
Does the DC charger come in two parts ??
If so check both parts, if you do not get a light on converter(square box) and did before it is converter...
May 17, 2012 | HP Compaq Presario C304NR Notebook
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
How can i restore a compac notbook presario cq60-615dx to its factory setting. thanks
Hi
Sometimes if you press the F11 or F10 key on startup it can take you to the factory restore
but please remember to save anything important to disk or pendrive because you will loose everything you have put onto your laptop
Jan 21, 2011 | HP Compaq Presario CQ60615DX Notebook
I have a compac presario cq60 with a blank screen. Screen went blank 2days ago. Need help please!
Without more information i would have to say that your inverter has died. The inverter provides light for your screen.
Oct 25, 2010 | Compaq Presario CQ60-204NR Notebook
My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Aug 16, 2009 | HP Compaq Presario CQ60-249US Notebook
Computers & Internet Logo
171 people viewed this question
Alun Cox
David Payne
David Payne
