Question about GE Refrigerators
Morel (GE) gsl25jftc bs frezer is icing up i have checked defrost heater el ement and has continuity, it coud be defrost sensor switch or defrost timmer how can i trouble shoot the last two comonents
  • 132 Answers
It will be the defrost timer. If you manually forward the defrost timer it will click into defrost mode. This will melt the ice. The defrost termination switch will stop the heater once all the ice has melted.
If defrost does not happen then it is a faulty defrost termination switch
Posted on Mar 25, 2011
Hi,my GE refrigerator have alot of ice in the frezer comparment hoy can i fix? Refrigetor side not cold. Thanks
First off,
Ice build-up in the freezer compartment is an indicator that the defrost system is not working properly.
The defrost system is composed of the defrost heater and the defrost thermostat. If one of them is not working, ice will build up in the freezer compartment.
You need to do a continuity test on the defrost heater and if it is good, very likely the culprit is the defrost thermostat. Just replace the thermostat
Aug 02, 2017 | GE Refrigerators
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
My 3 year old bottom frezer samsung fridge stoped defrosting automatically.Ice builds up in vents till stops cooling.After unpluging and defrosting for 24 hrs manually,works good for 2-3mnths.Cant find...
3 things defrost heater, defrost timer or defrost limit thermostat.
You can pull the cover inside the freezer exposing the evaporator coils,
look for the defrost heater at the bottom of the coils. Test for continuity.
Find the defrost limit thermostat, a 2" metal disc attached to the evap coil usually on the side towards the top has two wires going in and will have continuity only when it is cold. If those are good probably the defrost timer.
Nov 04, 2009 | Samsung Refrigerators
GE TBX18BLJ --Freezer comp frosts/ices up. Defrost
The next step would be to unplug the refrigerator and remove the rear panel and defrost so that you can unplug the defrost heater on one end and check the continuity. 305175 Defrost Heater and defrost thermostat Part number 3489. If you change the defrost heater you should also change the defrost thermostat. Let me know the results. Remember above 60 degrees the defrost thermostat will show open with your OHM meter. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 15, 2009 | GE Refrigerators
Need photo of Defrost Switch or Sensor
Unit needs to be cold when you test. it closes at around 20 or 30 degrees F and opens around 55 deg F
Jul 02, 2009 | Viking Professional VCBB363SS Stainless...
Tow dooe refrigerator and frezer, ice in the
likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Jun 29, 2009 | Refrigerators
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GSL22JFRE BS not cooling. I need help troubleshoot my GE GSL22JFRE BS cooling issue. I found a temporary fix from this website by open up the "frosting-panel" in the freezer and blow-dry out the ice. It...
Hi, Ifwhat you are getting is frost, remove the rear panel again and locate the defrost heater. There will be two wires going to it and it is fastened to the bottom of the evaporator coil.Remove the two phillips screws holding the heater and pull it out to remove the wires. Check the element for continuity. If there is no continuity on the element, replace it. If the element shows ok, locate the bi-metal switch that is fastened at the top of the evaporator coil. Test it and make sure it has continuity. NOTE: the bi-metal must be tested while it is cold.
The most common problem with this model is the defrost heater.
Vic
Jun 20, 2009 | GE GSL22JFR Side by Side Refrigerator
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Jun 25, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
