Question about Emerson Heating & Cooling
Are the new 3 ton Copeland Scroll compressors come with the start run, and the common posts showing continuity?
refritech08
  • 149 Answers
SOURCE: Copeland A/C compressor Phase monator
Are you good with wiring?? you can use replacement monitors is there a supply house in your area? just purchase replacement ones they have instructions on wiring them up. if you need any more help with the units just email me at hvac.tech7872pr@gmail.com
Posted on May 05, 2008
  • 182 Answers
SOURCE: Copleland scroll compressor failure
Make sure ALL moisture and noncondensables are evacuated while the system is down.I would have the line flushed to remove all remnants of burnout.Actually with the age of the unit and amount that needs repaired I would change the unit out to a 410a system and start over.
Posted on Nov 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: My compressor model #ZR36K3-PFV-230, Serial #97C53072L
You could possibly try a new capacitor. However,your condensing unit is 12 years old. Anything more than a capacitor would require the unit be replaced.
Posted on Sep 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: Bad compressor or bad capacitor??
Look at the capacitor. if it is leaky or swollen it is most likely bad
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 12, 2009
Testimonial: "Thank you for your response."
  • 308 Answers
SOURCE: How much does a Carrier ZR47K3 4 ton scroll compressor cost
between 1400 and 2000
Posted on Sep 17, 2009
Is my copland compressure cr32x6 pfv220 a scroll or hermatic type compressure
Reciprocating http://www.hvacpartsoutlet.com/Copeland-Reciprocating-Compressors-R22/
Oct 24, 2016 | Heating & Cooling
Package heat pump problem.
the gauge not changing and the pipes not sweating indicates the compressor is not pumping gas
I suggest that you call in an ac specialist to properly diagnose the problem and get a quote to repair
Aug 27, 2016 | Heating & Cooling
I have a goodman unit with a copeland compressor Its in Montana and I only ran it three time since the install. Some times it starts right away and sometimes it try's three or four time before...
When you say Montana the first thing I thought was, does it have a crank case heater? Is it actually working? May need a start cap installed, need to check amps at start up, possibly nearing locked rotor. Fan works every time?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 04, 2017 | Goodman Heating & Cooling
What is the HP rating if a 3 ton air conditioner?
Hi, this depends on the compressor that is installed in this unit. It may be a Copeland scroll, a Tecumseh, its hard to say. Most compressors are around 2 hp for a 3 ton unit. On the data plate it will tell you the h.p. of the blower and condenser fan motors such as 1/4 h.p., or 1/3. If you can get the name and model numbers from the top of your compressor, you can call a a/c, Refrigeration parts house, wholesale and they will have it in there manuals. The B.T.U. rating for your compressor is 36,000. There are 12,000 BTU's per ton of cooling, this is something that almost no one knows, but now you do. If it were a smaller unit such as a 2 and 1/2 ton, it would be 30,000 B.T.U.'s. You can look at the model number of a unit and you will see numbers like this, 024, 2-ton, 030, 21/2 ton, and 036 a 3 ton unit and so on. Your compressor alone will be in the range of a 2 horse unit, which ever the brand of compressor they installed in it. Please don't forget to rate me on this as I know you will be kind. I will be here if you ever need help on repairs or trouble-shooting your unit in the future, just use my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
New copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Apr 21, 2010 | Heating & Cooling
Need help in AC compressor replacement. The existing compressor number is C-SB351H6B and its a SANYO.? What is the BTU rating for this compressor and what would be the replacement with a copeland scroll...
This compressor has a rating of 56700 BTU at 45 deg. F Evap and 130 deg. F Cond.
Your supplier will match a copeland scroll using this rating
Fuji
Aug 03, 2009 | Heating & Cooling
I have scroll chiller contains scroll compressor tandom circuit. One of the compressor failure from it due to unbalance of the winding. Previously compressor thermistor opens two to three times. Also one phase open in contactor of the compressor. Can you guide me regarding the reason of compressor failure and what is the next step for the replacement of compressor. Also give guide line for the points take care.
Nov 02, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Emerson Heating & Cooling Experts
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
