Question about Car Audio & Video
The radio in our 2006 Hummer SUT just quit working the other day. Suspect a fuse problem, but not sure I have the correct location. Any suggestions?
  • 391 Answers
Hello there firstly check that there is current without connecting it to radio you can do this with multimetre ! if you are getting 13.8v at the connector ,it rules out power problem .... secondly check fuse at back of radio it might look ok but for the sake of it replace with new one a 5amp fuse will suffice this ,i hope ive helped you in someway ,goodluck
Posted on Mar 24, 2011
Engine code p2a01 hummer h2 sut 2006
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV, , owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
Mar 16, 2018 | Hummer H2 Cars & Trucks
Can someone tell me what fuse to pull-in my 2006 Hummer H2 SUT? I now need to pull the fuse and try to carefully extract the (all glass) portion of the # 194 bulb-which broke. Bummer.
Fuse rating are normally on the inside lid of the box cover. Fuses are colour coded. You wouldn't normally pull a fuse to replace a bulb. Power off, lights off, use tweezers to remove a broken capless bulb.
HUMMER H2 2006 fuse box diagram Auto Genius
Mar 13, 2018 | Hummer Cars & Trucks
Hi! I am hummer H2 SUT 2008(v6.2) owner from Russia. Have problem with heating/ajustment front seats(can't switch ON last couple days. Hope it is just fuse, but no idea - were it is located). Thank you in...
If you're finding it difficult to service/repair your car, get one of those online manuals. You'll not have to wait for others to answer, or rely on mechanics and all. Plus i know a website that sells very cheap but very very good
manuals online, without expiry i.e. for lifetime. www.reliable-store.com
Mar 08, 2018 | Hummer H2 Cars & Trucks
Is there a fuse box located inside the 2006 Hummer H3
On this website you find fuse box diagram and description for Hummer H3 (2005 - 2006)
Hummer H3 2005 2006 fuse box diagram Auto Genius
Sep 29, 2012 | 2006 Hummer H3
What's the capacity of the rear diff, I want to change the fluid. 05 Hummer H2 SUT
actually just fill till it comes out of the hole but generally will hold less than 2 quarts. make sure that you have the correct diff fluid and any additives that it requires. dealer can get you the correct additive. cheers
Dec 30, 2009 | 2005 Hummer H2
My horn is not working hummer h3 the fues is good can i have a bad horn
where is the hummer h3 horn located as i want to change it to a smaller airhorn? thx
Sep 18, 2009 | 2007 Hummer H2 SUT
Is there a reset button for the compressor-air suspension
When I replaced my air suspension bag it reinflated upon starting the Hummer. I did not have to reset anything. You may check the fuses in the event it ran so much to blow one and prevent the compressor from burning up.
Jul 09, 2009 | 2005 Hummer H2
How check hummer 2005 sut H2 before to buy
is the car low milage ? by taking it for a drive you will be able to tell if everything works and stepping on the brakes lightly you will be able to tell if there is any noise coming from them.. take it on the road and step down on it to see if it accelerates good.. make sure it shifts smooth and there should be no smoke coming from anyhere.. check under the hood to see if it is clean everywhere. this tells you if it has been taken care of .windshield broken? check for chips here also.. interior clean ? this lets us know if its been taken care of also... if its late model and low miles you probably will be ok.. driving it will tell the story about how it is going to run ... holler if you have more.. Jerry
Apr 28, 2009 | 2007 Hummer H2 SUT
I just got my 2007 hummer h2 sut, but I don't know how to turn on
The fog lights run by default during the day in the "auto" position. To activate the headlights and the fog lights you need modify the jumper position in the fuse box for the lights. "see fuse box diagram"
Apr 05, 2009 | 2007 Hummer H2 SUT
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
