I have a ProScan 80 series, 32 inch TV. I turned it off, and now it won't turn back on. nothing can make it power back up
I have had mine repaired for this exact problem several times. First it was 164589 + Filter Kit+Fuse 6.3A+IC3107; Parts $60 Labour $125. Next unknown repair $208; next 20787 diode+1000MF/50VDCfilter+10R resistor; total $247;
next 213985 tuner $305;
next 164874 diode+160085 diode+++; total $209
Etc. ad nauseum. A lemon from the start. Went out and bought a 52" plasma on sale for less than it was costing me for the darned repairs every 12-18 months.
Posted on Feb 23, 2010
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
32 in proscan lcd tv just turned on tv and colours were all distorted
Try hard reset, unplug TV, wait 10 min. and plug back in.
. You may have to reset your setup configuration back to how you preferred. hope this works for you
Jan 14, 2016 | Proscan 32LB30QD 32 in. LCD TV
Proscan tv
There should be a short circuit to any of its internal board. If power supply switches on, and TV do not work, check the main digital board for fault. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32LA30Q will not power on
It appears to be a 32 inch.
Some questions:
Does power light come on and if so what color when set is off?
Were you having any problem before where you had to turn set on several times to get it to come on and stay on?
I am here to help you.
Mar 14, 2012 | Proscan 32LA30Q Television
Proscan 32LA30Q won't power on
Some questions:
Tv turns itself off as soon as it is turned on. it is a 32" proscan hdtv and dvd combo.tried switching power cord,power supply, way it is powered up nothing has worked.
This problem usually occurs as a result of overheating in units. The unit is meant to be placed in a location where enough breeze will be accessible to avoid over heating in the unit.
Hope this solution has been helpful?
Oct 24, 2010 | Proscan Televison & Video
I bought a new 27 inch proscan in 1991. It was
This is probably a tv with the "ctc-169" chassis. The BEST modern chassis RCA built. I own 2 of them that I USE, one is a 32" CONSOLE, a lot like your 27" set the other is a projo. I would keep BOTH of them ANY day--over ANY of the cheap, unreliable, fragile flat--panel sets today!!
FIX your set!! If the picture was good--it still will be--these sets had GREAT tubes in them. Most likely--a power supply isue with a couple of caps in the power supply, perhaps the controller chip for the chopper transistor, nothing likely serious. Probably about 150 repair--or less.
Oct 10, 2009 | Proscan Televison & Video
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
324 people viewed this question
Top Televison & Video Experts
