Question about HEALTHRIDER H75T Treadmill
Cannot lower my h75t healthrider treadmill - HEALTHRIDER H75T Treadmill
3 Suggested Answers
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
How do i let my healthrider H75t trademill down
Hi There ,
Put one hand on the rear roller and push up slightly to take the weight off the mechanism
use the hand to pull out the black knob .
Whilst holding the knob out let the machine lower slightly and release the knob and then let the machine lower itself .
Sep 22, 2014 | Exercise & Fitness
How do I unfold the health rider h75t
Guys ,
Try rewarding your body by feeding it isagenix
Warm regards
Isagenix Consultant
www.msranderson.isagenix.com
The Isagenix Wealth Creation solution
Cleanse for Life
The Isagenix Weight Loss Solution
The Official Site of Isagenix International
Jan 26, 2014 | HEALTHRIDER H75T Treadmill
Smells like *****
Hi Larry,
What are you asking ?
Dec 13, 2013 | HEALTHRIDER H75T Treadmill
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Jun 29, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Tread mill doesnot move
Could be several problems. You can isolate the motor and use a DC power source (power tool battery, Lantern battery)to check if the motor is good. If the motor is good then check to see if under the motor hood you have a "Tech Sheet" which should help you with the diagnosis. We use www.treadmillpartszone.com for parts.
Jul 28, 2010 | HEALTHRIDER H75T Treadmill
HEALTHRIDER H75T Treadmill Logo
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
greg kinsley
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
