Question about LG Heating & Cooling
I am a student at blue ridge community colledge and we were looking at one of your mini split system diagram and could not figure out what cn-4way. what the cn stands for .we looked for a ledgand on the unit and in the manual.
    Brigadier General:
  • 4,736 Answers
Jtfisher72, unfortunately, you're are not communicating with the LG company, with your post here on FixYa. I really wish I could help you figure it out. But, I do have a Customer Care phone number for LG, that you can use to hopefully get the answer. Be sure to have the Model # handy when you call,
800-243-0000.
Posted on Mar 24, 2011
I have 95 pontiac grand prix se and the 4way flashers work but the blinkers don't work I have tried the fuse and even changed the flasher canister but they still are not working. what am I missing?
Don't know what your missing ! Yes i do , your guessing ,not testing . Do you know what a wiring diagram is ? What a DVOM - digital volt ohm meter is ? How to use them to test electrical circuits ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle year , make , model an engine . Under system click on lighting , then under subsystem click on hazard lamp . Click the search button ,then the blue link. After copying an printing this diagram go back to the beginning an click on turn signals an copy an print it .
Electric Testing Techniques You Need to Know
Apr 21, 2018 | Pontiac Cars & Trucks
Tip
4 way switch
If you wish to control a light or lights from more than 2 places, then you need a 4 way switch in between the 3way switches. You can use any number of 4 way switches in a lighting circuit.
To rough wire the switches, run a 3wire with ground cable from the 3way thru the 4way(s) to the other 3way. As in the 3way switch wiring the light and power can be at either end, that part does not change.
The diagram for the addition of a 4way switch looks like this..
The travelers from the 3way switch connect to like colored screws on the 4way .. If more switches are wanted, just add them in the center of the circuit in the same manner as the first 4way .
on May 14, 2010 | Hammering
How old do you have to be to start online classes for colledge before you graduate and leave for colledge
You will need counseling on your options. Talk to your school counselors. Make sure anything you pay for is accredited.
Jul 08, 2014 | Computers & Internet
Can not find drain on2011 blue ridge fresh water tank the belly is totally enclosed and can not see any tanks at all
Look for a short plastic water line protruding under with a cap or tap on it. Should be roughly in line with Potable fill inlet. Get right under and look around frame area as well. Locate pump and look in that area as well.
Jun 05, 2014 | Forest River 2013 Blue Ridge 3025RL
Where can i get a copy of the instructions
Thank You very much for using Fixya.
As you have asked here is the site which will help you to get the instructions:
http://www.hoslotcarracing.com/Layouts.html
Regards!!
Aug 16, 2012 | Afx 4way Split Set 176
LOOKING FOR ELECTRICAL DIAGRAM AND OPS MANUAL FOR HAIER HSU-22VCA MINI SPLIT
I cant find the manual but I can help you this the issue you might be having. Let me know. http://www.myminisplit.com
May 14, 2010 | Haier HSU22VCA 22000 BTU Cooling Only Mini...
Need diagram for f250 v-10 serpintine belt
Look the fan shroud or radiator cover for a picture of the belt diagram;
If not there, you can thread the belt behind the fan then you can thread it over a blade and turn the fan, thus not having to remove the fan. Once the fan issue is resolved or not an issue and you cannot find the threading picture, then you can use your common sense to figure that the belt must be driven by the crankshaft and look at the ridges on the belt to decide which side of the next pulley that needs power and continue this process over and around each auxilary unit until you are sure of the threading then put your 1/2 drive ratchet into the tensioner and move (raise or lower) it asside making sure that all the little ridges are in place on the ridged pulleys then release the tensioner. That should do it.
good luck
Jan 01, 2009 | 2001 Ford F250 Super Duty Super Cab
Heating & Cooling Logo
102 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
