Question about Whirlpool Dehumidifiers
My dehumidifer is freezing up what could b wrong
    Brigadier General:
  • 4,736 Answers
If the air intake filter is dirty, that can affect the operation and cause it to freeze up. Operating in temperatures below 40 degrees will also cause it. Or a low refrigerant level can also cause it. Turn the unit OFF and unplug it. Place some old towels under the unit to absorb any dripping water. Once the unit has completely thawed, remove the filter and clean it. Carefully replace the filter (be sure it's dry) and give the unit a try.
Posted on Mar 24, 2011
How do i know if dehumidifer is is low on freon not taking much water out of air
Hi, Usually if it is low it will start to freeze up but if you have a freeze control unit then the compressor just won't run much...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 19, 2011 | Soleus CFM-40 Dehumidifier
MODEL DM 162EBS. Why is it when I switch my dehumidfier on 10 minutes later it goes to defrost. [ WHY?]
Let's think thru the dehumidification process--
A dehumidifer needs to create a COLD surface, on which to condense the moisture in the room.
If your room is quite cool, it is esily possible that the COLD surface can go below freezing-- Now the water is trapped in the ice-- So-- it has to defrost, to melt off the ice, and start all over again!
Can you move the Dehumidifier to a warmer spot-- maybe near a radiator, or a heat register? -- You will remove much more moisture in that way, too..
Just a question: Most homes are WAY TO DRY during the winter months-- are you sure you need to dehumidify your living area? (Maybe you are drying the basement?-- or a wet area?)
Just seeing if I can help
Mack B
Jan 20, 2011 | Dehumidifiers
The dehumidifer runs but does not collect any water.
my dehumidifier runs but does not collect any water.What is wrong with it
Oct 13, 2010 | Maytag M3DH30B2A Dehumidifier
Why does dehumidifer ice up
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jun 28, 2010 | Eva-Dry EDV300 Dehumidifier
Power on but not dehumidifing
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 24, 2010 | Maytag M7DH45B2A Dehumidifier
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
Goldstar - 2 year old -dehumidifer - cannot be switched off - collects water but freezes up with condensation and ice on the outside of appliance
This often happens because the room is too cool...
warm up the room to 65 or better and you will be okay..
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 22, 2010 | Dehumidifiers
Amana 30 (looks like dk25) unit runs but coils freeze up
Most dehumidifiers have a defrost mode in which the compressor is turned off to give time for the frozen water to melt. The freezing problem ocurrs when the unit is used in very cold weather. Check your manual to see if this unit comes with automatic defrost mode. If it does, it would appear that it is not operating correctly and you can request warranty service. If no defrost mode is available, then your only option is to heat up the room in order to use the dehumidifer within its limit of operation. Some units can operate as low as 36 F, but most units cannot go that low. Find out what your unit's specs are from the manufacturers web site.
Jan 04, 2009 | Amana D530M Dehumidifier
Seems to freeze up
I am guessing the system has a leak and you are very low on coolant, I have had the same problem. I assume its still under warranty.
Sep 23, 2008 | LG LHD65EBL Dehumidifier
Dehumidifiers Logo
244 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
