Question about Thermasol Elite Control Package
Control pad reading "err5". what does that mean
Depress heat heating pad flashing won't go on
Hello, Linda -
Do you perhaps mean an Xpress Heat heating pad? If so . . .
http://feelpainrelief.com/does-sunbeam-xpressheat-heating-pad-extra-large-deserve-its-best-seller-spot-on-amazon/
(Quote)
How to Use the Heating Pad
When you get your package, the cord and the heating pad are not connected. Before plugging the cord into the outlet, make sure that the cord and the heating pad are connected. Yes, the control/cord must be connected to the heating pad before plugging it in. If not done in this order, it might cause a blinking F in the display and the pad will not heat up.
(End quote)
More . . .
Flashing F
Some users experience a flashing F (meaning failure), in the display. Make sure that the cord with the display is connected to the heating pad BEFORE plugging it into the electric socket. The flashing F can be avoided by doing this. If you still get a Flashing F, disconnect from the electric socket, make sure the cord is tightly connected to the heating pad, wait 2 minutes and then plug it back in.
(End quote)
More . . .
Customer Support and Warranty
This heat pad comes with a 5-year limited warranty. This means that for 5 years it should be:
Free from defects in material and workmanship. If there is any problem with the above after normal use, they will repair or replace this product or any component of the product found to be defective during the warranty period.
What you need to do is keep the original sales receipt/order and call the following number:
  • In the U.S.A. - please call 1-800-435-1250
  • In Canada, -please call 1-800-667-8623
They will help you out if you run into problems.
(End quote)
Best wishes.
Mar 04, 2018 | Miscellaneous
What does PSTD stand for on the remote?
Washing Machine ' FAQ ' Help & Troubleshootings ' Haier ZA
www.haier.com/za/help_and.../faq/washing_machine/
HaierQuestion : Error Code-control panel display "Err2" · Question : Error Code-control panel display "Err5" · Question : The door lock light flashes 8 times and stops .
Oct 29, 2015 | Haier Televison & Video
The digital display for a Magic Chef gas oven reads "5 A6", what does that mean?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Mar 21, 2013 | Kitchen Ranges
Roomba err5
please go to the page and see the video, instruc, manual , maintenance, tip, and fix it your problem easy.
http://homesupport.irobot.com/app/home
God bless you
Sep 22, 2012 | iRobot Roomba 550 Vacuum
HELLO. I HAVE A GE MICROWAVE MOD JE1860WB. THE MONITOR READ "F3" CODE. WHAT IS THAT?
The F3 code means that the Key panel also called touch pad is shorted. This code usually comes up when when the Microwave detects the shorted panel continuously for over 60seconds.
To correct this error, you have to Replace the key panel also called the touch pad.
Thanks.
Sep 14, 2011 | GE JE1860 Microwave Oven
My raypac 2100 was working fine, recently replaced control pad. Today set heater to 90 it heated to 89 then pad read "off". Pad would not respond after that. Turned breaker off then on and error...
The EOL code means End Of Line. It means the heater has given up trying to run. There are a number of problems that could cause this issue. There could be no gas pressure, a defective gas valve, or something wrong with the control board, etc. To determine exactly what is wrong a person qualified to diagnose the problem will need to follow a diagnostics document from Paypak or call Paypak's technical support line. If you have a volt/ohm meter and have some debugging experience you might convince a tech support person to help you diagnose what the problem is. If you are not successful with that idea then you will need to find a pool equipment professional to do the job. I hope this helps.
Aug 22, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Am getting an "F-1" reading with a "beep"
Error code F1 means failed thermistor/transistor in control.
To resolve this issue you'll just have to replace the Electronic Range Control (ERC).
Good luck.
Apr 11, 2011 | Magic Chef 9815 Electric Single Oven
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
I have glass top bathroom scales eks. reading err5 any ideas how to fix? javan
Hi take the batteries out then put them in again that should solve the problem
Jun 28, 2009 | MedWeigh Health & Beauty
Thermasol Elite Control Package Logo
Top Thermasol Electrical Supplies Experts
woodzowl307
Jim Goldsmith
Jim Goldsmith
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
