Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
I am having a hard time getting my yardman to start, how do you prime the mower?
    Novelist:
  • 111 Answers
This unit does not have a primer. It has a choke cable. If the unit does not want to start when you have the choke engaged you may need new fuel or need to clean the carburetor. There could be water in the carburetor. To check to see if you have water in the carburetor you need to loosen the nut on the bottom of the carburetor (it helps to pinch off the fuel line to keep fuel from coming through the carburetor while you do this) and take off the fuel bowl and see what is in the carburetor. Most of the contents of the fuel bowl will drain out but there should be enough left to see if there is water or dirt mixed in with the fuel. When you take off the carburetor fuel bowl check to see if there is any corrosion on the carburetor. This may have a white, chalky appearance or if it is varnish from old fuel it will look like the carburetor has a "gold" appearance. The correct color of the carburetor is a dull or flat grey. If you find water in the carburetor bowl then there is a good chance that there is also some water in the fuel tank. You will need to drain the contents of the fuel tank. If you want to see what the fuel looks like you can drain it into a paint mixing cup or a clear jar. Start with a clean jar or cup, to make sure that you are seeing what is in the fuel and not what was left in the cup. lol. When you have drained the fuel tank and made sure there is no water in it, I would suggest putting fresh fuel back in the unit. See if the unit will start and run ok. If the unit pops or sputters while the engine is running there may be some more water that will come out after the unit is run for a little while. If the unit continues to not run or is not running very well you may have to clean the carburetor. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. You can get this part from www.mtdparts.com. Best of luck.
Posted on Apr 03, 2011
I can a YardMan 20 1144cn lawnmover that will start after priming the carb, however immediately shuts down...please help
It sounds like the main jet is plugged. Remove the float bowl from the carb.... Better yet, there should be a video on Youtube.
May 15, 2013 | Garden
I have a yardman lawnmower it has gas, oil level is good but wont start,even after priming, priming is 3 pushes of the prime button, i did as directed and still wont start after pulling the cord for 15...
If the fuel pumped when you prime then the next step would be to check the spark. This can be done by removing the spark plug and then reattaching the wire to the plug and grounding the plug to the engine block. Then you need to have someone to try and start it, while watching for spark. It is easier to see if this is not done in bright sunlight. If no spark seen or heard, then it is either the spark plug or the ignition module, most likely the spark plug. If you have another machine available you can pull the plug wire and hook it to the plug from your mower and ground it to the block and try starting. If you get good spark, then the problem is the ignition module, if no spark, then replace plug.
Sep 15, 2011 | Yard Man Garden
What is the proper weight oil for most walk behind mowers.
SAE 30. If you run synthetic (hard to find in SAE 30W) then you can get away with using a muti-viscosity oil like 10-30W. Briggs and Stratton are very adamant that ONLY SAE30W be used in their small engines.
May 07, 2011 | Yard Man YardMan 173 cc OHV 19" 3in1 Rear...
Yardman 6.5 HP XL 21'' CUT S/N#D06786CN
See if it will start with a little splash of fuel down the carb.
If it starts for a second you probably have a plugged main jet.
The mowers collect a little bit of fuel in the bottom of the carb and then water comes along and it makes rust and gunk and turns the brass stuff all green. You remove the main jet and clean the two holes on the bottom and the little tiny hole at the top of the threads *(you should wire brush the threads and get a tiny piece of wire strand to clean this jet.)
I know you ran the mower till it ran out of gas....but that was only till it ran out of enough gas to fuel the main jet. There was still fuel residue in the fuel line and the bowl.
This should be a fast fix though. Good luck and be careful!
Jul 18, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I prime my tecumseh engine three times as stated. The lawn mower still will not start. How do I investigate to figure out what is wrong? I have taken it to a repair man twice. After I get it back it will...
This sounds like a fuel delivery problem. Maybe remove the carb and tear it down and then soak it overnight in a cleaner after removing all the moving parts...not real hard normally...then let dry and reassemble...If this doesn't improve the fuel delivery problem, maybe get another carb for it....Make sure the air filter is not plugged up, blocking air flow to the carb itself..just something to make sure of at first.
Jul 17, 2010 | Toro Lawn Mower With Toro Power Tools
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
I have a Yardman 12.5hp 38"in cut mower.
you might want to get a book on this mower spring are fasen all kind of ways its hard to tell how to do it with out look at it
Jul 20, 2009 | Garden
Where is the carb on a yardman 6.5 hp?
It will be by the push to prime button, and under the air filter.
Jul 07, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
353 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
