Question about Apple iPod MA446LL/A MP3 Player
My 2gb ipod,when i fix it in the computer it is not noticed,and also when i turn it on it starts to load by showing an hour glass and then starts to blink all the way.the model no of my ipod is A1199emcno..2115
SOURCE: Problem with IPod Nano Model A1137
Try holding the menu button and center button at the same time. this should reset the ipod completely. Its a force power up and power down similar to Zapping your PRAM on a computer. this should reset the configurations
Hopefully that helps
Posted on May 17, 2008
SOURCE: ipod not playing songs
i had the same problem too :S
but i converted the songs to aac (via itunes) and everything seems to work fine now :)
give it a try
Posted on Sep 10, 2008
ginko
  • 19396 Answers
SOURCE: Drivers
The drivers for Ipod are included with Itunes, you need to install Itunes before connecting the Ipod.
Here you find the downloads:
iTunes 8 for Macintosh
iTunes 8 for Windows
Here you get the rest of apple downloads for Ipod:
Apple - Support - Downloads
Posted on Sep 30, 2008
  • 13433 Answers
SOURCE: I can't un lock the volume lock I forgot the code
Hey,
one of these pages fill solve your problem
either this
http://www.fixya.com/support/r561879-code_forgot_code
or this
http://www.fixya.com/support/r538899-unlock_ipod_volume_control
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
mneilsen2084
  • 342 Answers
Have you already reset the iPod? (Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.)
If this failed I would suggest going to: http://fixyouripod.weebly.com/
and view the free video's about resolving this kind of issue. If after that the issue is still not resolved, Please do let me know. :)
Posted on May 16, 2009
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
When my ipod is turned on,it shows an hour glass in blue screen
Not knowing what you have tried I would suggest you follow the iPod troubleshooting guide at Apple.com . The steps get progressively more severe feel free to skip any of the ones that you've already tried.
If it's a software and not a hardware issue the restore process should fix any software problem. Be aware though that all data on your iPod will be lost and will have to be put onto your iPod again from your computer which can take a while.
May 29, 2010 | Apple iPod touch
My craig mp4 player shows an hour glass and will not work.
Turn on the MP4 player and let the battery go all the way dead. Plug it back into a computer and mine reset.
Dec 09, 2009 | Craig CMP168C MP3 Player
Hour glass show... as like a hang status.. plz help me...
Is it detected in itunes? You're supposed to press menu & ok button only after the following steps- 1.turn off your ipod if its on. 2.slide the hold button on and off a couple of times and then when hold is in off position,press and hold centre and menu buttons till a silver apple appears on screen.then connect to itunes and restore.
Sep 02, 2009 | Apple iPod nano
I jus gotta new ipod nano 2gb, i plugged it into the comp and it shows apple sign then "do not disconnect". a auto play window opened and it appears in "my computer". i click on it and it shows three...
First, you should use itunes for you iPod. I know that there are other programs that can let you load music on it, but you should use iTune, Really.
1. You should first download iTunes. It is free.
2. Next. Load your music into iTunes. Do all of this BEFORE you plug your iPod into the computer.
3. Connect your iPod to the computer. Use a fast USB port. These are usually located on the back of the computer.
4. Your iPod should appear in the iTune pane on the left side. You should be able to see a set of 'tabs' that you can click. The first one is about your iPod.
5. At this point, you can click on the music tab to tell the computer to load what to load into the iPod. Click 'sync' to load your music.
6. When the syncing is complete, you will see that notice above in iTunes. Click the arrow next to the iPod picture in the iTunes pane to discharge the iPod. The iPod picture will disappear. Make sure that you also safely release the iPod in the task bar at the bottom of the computer. You will need to click on a green icon that looks like a plug and select 'safely remove storage device'. Wait until the computer tells you it is safe to disconnect it. Then disconnect.
Hope that helps.
Dec 19, 2008 | Apple iPod nano
Apple iPod nano Third Gen... Problem
Is that a real ipod? hourglass.. it sound fake to me.
May 30, 2008 | Apple iPod nano 3rd Generation
Frozen screen
my ipod wont turn off or nothing i tried downloading music like i always do and my ipod shows that picture of the plug and it says under it "ok to disconnect" it wont turn off or nothing
Dec 27, 2007 | Audio Players & Recorders
Ipod not playing songs
restore to factory setting using the software. that could help.
Nov 24, 2007 | Apple iPod nano
Hour Glass Hangup on Ipod NANO 2nd Gen
hmmm, sounds like you might have to reinstall the O.S I think when you connect to yr computer does the ipod still show? have it connected whilst running a general disk repair program and see if that makes any difference btw-not sure if u use mac or pc but dont use any nortons repair apps with the ipod, whatever your flavour computer
Aug 14, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
