Question about Windchaser Electric Radiant Heater (1500W)
Hello I have a windchaser model #RH201 Item # WHR204 1500 Watts heater. The Alarm lighs comes on however there is no heat. what is the problem?
****. Me too
Posted on Dec 10, 2011
Windchaser tower ceramic heater model/ cerc1lb
The oscillation mechanism has failed - a frequent problem with this type of heater.
Dec 04, 2016 | Windchaser Heating & Cooling
Why does this thing not run continuously and stay on long enough to heat up a room?
I would guess the over heat sensor has failed .contact the manufacturer customer support
Jan 25, 2016 | Windchaser Heating & Cooling
Need a manual for a Windchime PAC9 Model SA 12059 Air Conditioner, or advise on how to bet alarm light to turn off so unit will work
on the WEB
Windchaser PACR9S Instructions Manual - ManualsLib
www.manualslib.com > ... > Air Conditioner > PACR9S
View and Download Windchaser PACR9S instructions manual online. WindChaserProducts Inc. Instruction and Maintence Manual Portable Air Conditioner ...
Aug 04, 2015 | Windchaser Heating & Cooling
I have a poloma model PTG-74PVP hot water heater. This morning we went to use it and it will run a minute or two the flash alarm 35. We have had the unit for four years with no problems what so ever.
rtgl-74xp.jpg RTG-95XP Item Name: Outdoor Rheem Tankless Water Heater RTGL-74XP Item Price: $910-$1100 Gas Type: Propane Venting: No Item SKU: Rheem RTG-95XP replaces RTG-74XP Product Description: Rheem Tankless Water Heater RTG-95XP
Be aware of this --- http://www.cpsc.gov/cpscpub/prerel/prhtml07/07108.html
And this ---
This makes getting information hard to come by. Please use the link below for information.
http://www.rheemtanklessonline.com/contact.php
Feb 06, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
Need Owners Manual/Assembly Instructions for WindChaser PHS Patio Heater
I have the exact same problem. No owners or assembly manual. Can get no response from company?
Nov 04, 2008 | Windchaser Stainless Steel Patio Heater...
Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Feb 22, 2008 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
