Question about CyberLink PowerDirector 8 for PC
I'm having a problem taking videos from a dvd to put in power director workspace
  • CyberLink Master
  • 1,381 Answers
Hi vqnessavann
PDR 8 will run smoother if you first import the content of the dvd on your HDD in MPEG format .
Secundly , it won't work if the content is copy protected .
Otherwise , use a third party software such as TMPGEnc , NERO ... etc ... to convert VOB ( dvd ) files into Mpeg files .
To decrypt protected dvds , you can use free DVDFab HDDecrypter .
Best regards,
fanaudi .
Posted on Mar 24, 2011
Cyberlink Power Director 14. Burning Unsuccessful. Error eFF030C00
DVD-R disc probably defective. Source for another make of DVD-R disc and try again.
DVD capacity matters; how many Gigabytes of data can it take/record/accommodate
4Gb
8Gb
Oct 13, 2017 | CyberLink Computers & Internet
Creating dvd from JVC Everio
What kind of file is stored on computer, what extension (eg *.avi)
Jun 01, 2008 | JVC Everio GZ-MG21 Camcorder
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
When i connect my screenplay director to my tv the picture is in black and white, how can i fix this problem?
Confirm that the ScreenPlay Director is correctly connected to video input on your TV set.
Make sure the ScreenPlay Director is connected to power and turned on.
Make sure you have selected the correct video input on your TV to display output from the ScreenPlay Director.
The video output setting on the ScreenPlay might not be correct for your TV. Press the TV SYS button on the remote control repeatedly until the screen displays normally.
Try on a different TV, you TV may not be supported with this device.
Oct 25, 2010 | Iomega ScreenPlay Pro MP3 Player
The movies come out distorted
had the same issue. the problem could possibly be:
bad disc burner
wrong disc format
or simply the quality of the program
i had this issue with power director 7.0 and i payed for upgrades and it worked fine. the quality is poor with these programs, and instead of wasting time fixing it, i would suggest investing in a pc or mac disc software for making movies. my power director came with my computer, but if you purchased yours, i would take a look at your burner or disc. overall, i think this program has poor quality, and its not worth your time. i hope this helped, and if you wish to continue using this software, look into the following problems above.
May 15, 2010 | CyberLink SW- DVD Software Power DVD...
I have Windows XP home\service pack 3 AMD
you may need to install proper codecs for the output format of your camera. use klite codecs(you can find it on the internet for free). try to use vlc or mplayer and see if you have the same problem.
post again if you haven't solved your problem. i'll keep an eye
Jan 26, 2010 | Computers & Internet
Burning of DVD from Power Director V7
LOOK IN TOOLS AND SETTINGS OR HELP AND FIND THE UPDATE BUTTON AND UPDATE THE SOFTWARE. PLUS YOU ARE RIGHT THAT IT MAY BE PROBLEM USING EXTERNAL DRIVE.(IS IT USB 1.0?)..COPY YOUR FILE TO A TEMPORARY FOLDER ON YOUR DESKTOP AND BROWSE TO THAT FOLDER WITH POWER DIRECTOR.
May 28, 2009 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
Camcorder jvc
Use power director from power dvd suite
Mar 31, 2008 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
CyberLink PowerDirector 8 for PC Logo
96 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
