Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
When you put the charger they have light and no power
  • 206 Answers
Please remove and clean the Battery terminals of the Notebook, make sure that the output pin of the AC Adapter is properly connected to the notebook. The fault might be either with the output pin of the AC Adapter or Input DC socket of the Notebook.
Posted on Mar 24, 2011
I jhave a Jazzy Select GT power chair, I put the charger on it when the light shown red and green, when it powers up when charged the both lights will turn green, but now it will do nothing with start
Hi Gloria,
The first thing you need to do is measure the voltage at the charging socket of the Joystick (outside 2 pins). This will determine a lot of things, so I can guide you further.
Nov 21, 2014 | UPG 12V 35AH Jazzy Select GT Power Chair...
Why does my garman not come on when plugged into car power source, and power light shows green light?
Your car adapter wiring might be faulty.. Green light shows it is receiving power from your cig socket but there isn't any power from the adapter to the plug to your gps..
Jul 19, 2014 | Garmin nuvi 1450 GPS Receiver
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
I cant get any power and i have had the power chair for a few years orginal batteries and it ussed to work what do i do
lil plug in the charger for your chair and then turn on the power and see if qall the lights on the battery level light up if they do then the charger is putting voltage to charge your chair. unplug the charger and try turning the power on if it doesn't come on then you need to have the batteries replaced Hope this helps you
Apr 25, 2011 | Health & Beauty
My hp nx6110 don't get power either from the battery or the charger
Do this first, remove battery and charger, press and hold down power button for 10 seconds it will drain the power from the system esp the static electricity, then put the battery and charger back,
> if still no go, check for indicator lights on the charger, if your charger does not have indicator lights, try it on another system to check that it's not the charger that is having problem
> Possible that the battery is already drained and the charger is having problem, so if teh charger is working on another system and not in yours there is a problem on your computer
> You can also try turning on system with just the charger
> If another system is not available to try the charger get local help because problem might be on the mianboard.
Jun 03, 2010 | HP Compaq nx6110 PC Laptop
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
My imate Jam wont powerup
Just put the charger in the device and then soft reset it light will turn to yellow. if this dosent work try to put the charger and then remove the battery and put it back to phone while the charger need to be remain connected.this is gonna work
cheers
Mar 05, 2008 | i-mate JAM Pocket PC
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
158 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
