Question about Samsung HTC550 Theater System
Shuts down after around ten min. - Samsung HTC550 Theater System
    Habit-Forming:
    Scholar:
  • 76 Answers
Any electrical device which shuts down after a period of time is usually over heating. Turn the device off, clean out all fans and vents on the device with compressed air and move any other objects away from the device so that it has room to breathe. If this works then you need to keep the device away from other electrical equipment and keep the fans and vents clear for air to circulate.
Posted on Mar 24, 2011
How do I reset the security system on a 2001 Oldsmobile Aurora
If the security light is on you can try the 10 min. relearn procedure . Turn the key to run ( not start ) an leave the key on for ten min. If the light goes off in ten . min. turn the key off . Then start the vehicle . If the security light doesn't go off there is a hard fault an you will need to have it diagnosed by a repair shop that knows how .
Jun 21, 2016 | Oldsmobile Cars & Trucks
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
My hp pavilion dv9720us will run for about ten mins and then shut off
you can try to hover around the fan outlet the dust gathers and stops the cpu cooling down and then the cpu wiil shut down to protect the laptop from overheating if it runs longer but shuts down you will need to get in to the laptop and do the same around the heatsink fan and cpu
Jan 08, 2013 | HP Pavilion dv9000z Notebook
What should the fuel pressure be for 1997 k1500
should be 52psi to 58 psi on good fule pump with low or no leak down after it is shut off for ten min. on more then 2 to 3 psi after shut down, if so check presser reglator, and fule pump feather out.
Sep 18, 2012 | 1997 Chevrolet K1500
Car shuts off when it gets hot
your ignition coil are going bad, they need to be replaced. once the car gets hot the circuit shut down the car when hot. once they cool your riding again until they get hot. thats your problem. Good Luck
Jul 31, 2010 | 1988 Buick Electra
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
appliancepartspros.com
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
Won't download 1.5 update for ps3
It may be your internet connection, or you may not have enough space on the drive. How big is the file, and how long have you left it to run? if its a update for a game like a expansion pack, it may be around such and such GB and depending on you internet connection it might take up to a hour or two.
Regards
Jul 22, 2009 | Sony PlayStation® 3 (80GB) Console
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Shuts off after 20min
found cold connection on board at tuner
Feb 14, 2008 | Televison & Video
Samsung HTC550 Theater System Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
