Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer wont print. screen say it is off line or not connected. please help. i have looked at back of printer and hard drive and canno find a port to plug the wire into. The end of the wire has a plug that looks like it would fit into a telephone jack. thank you for any help you can provide. sincerely, gail garrington
  • 310 Answers
First check the usb cable to be ok,the connection on the printer-computer be ok,try to change the usb cable,reinstall the driver,if the problem persist maybe is the logic board broken.
Posted on Mar 24, 2011
Attempting to FAX...ErrorCode OxAF8D...cannot find this code in manual.
Where do you initiate faxing - from your computer or using the printer operator panel?
Try the following steps to determine what is causing this problem:
  1. Disconnect the printer from the phone line from the wall.
  2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  3. When the printer turns on, try to make a copy or print from your computer to verify that the printer is working normally without connecting to the fax line.
  4. If copying or printing from computer is working properly, then connect it to the fax line.
  5. Try to send a fax from the printer operator panel.
  6. Try to send a fax from your computer. If error appears, try to update your printer software by inserting the printer's installation disc into your computer hard drive.
I hope this helps.Please keep me posted.
Nov 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have my Canon MX420 printer hooked up, my computer recognizes it's existence, and the printer prints fine by itself. However, every time I try to print from my computer via wi-fi, my computer says...
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Aug 24, 2011 | Canon Pixma MX420 All-In-One Printer
Canon MP640 has 6C10 error, I have used the service mode and restore button x4 to reset absorber counter, but this stops the error until you go to print - then the next document returns the same 6C10 error...
my canno mp640 will not print in black, have replaced the 521/520 carterages new also a new printhead, and stiil it will not print,yet it prints colors ok. can you help please
DD.
May 12, 2011 | Canon MP640 All-In-One InkJet Printer
My ricoh aficio 2232c was unplugged and when I plugged it back in it keeps saying Please Wait across the screen and doesn't do anything else. Please help
If no error code comes up then you have a hard drive error in your Print controller.
Remove the back cover (unplug machine) remove the cover for the controller (controller is in upper right on rear side of machine and disconnect the hard drive.) Plug machine back in and see if it comes to ready. if so replace the drive, if not controller is bad.
Jan 19, 2010 | Ricoh 6513 Copier
Printer wont print. help!!
Hi albookristin
I believe evrytime you tried to print, they all lined up in a queue for printing. If that is the case, you have to delete everything in the queue
Right click on the printer folder, look under documents, and see there are documents listed. If there are few, delete all of them. In some cases, you may have to print one at a time.
After doing all that, try to print a document. For test purposes type a one line document and try to print it.
Hope this will work for you.
Have a good day
luciana44
Nov 15, 2009 | Lexmark X2500 All-In-One Printer
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
My phone wont connect to the computer
Try to transfer via blue-tooth
Jul 16, 2017 | LG KU990 Viewty
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
Sep 24, 2008 | HP DeskJet F380 All-In-One Printer
Data Light comes on - boots up but stays on wait - please help!
Network printing was optional. The network connection is misleading; it is there for scanning. You may have to use it as a local printer and share it.
Dec 08, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
