Question about Asko TouchProof D3232XL Stainless Steel Built-in Dishwasher
Need repair on a D1996 Asko dishwasher. Power button failed.
5 Suggested Answers
fgainer
  • 54 Answers
SOURCE: Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Posted on Feb 02, 2009
  • 901 Answers
SOURCE: Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Posted on Apr 15, 2010
Daniel S
  • 4323 Answers
SOURCE: We need a new control
Hi
You can click on this link to buy control for your Asko D1996. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 09, 2011
jyackle5
  • 8197 Answers
SOURCE: replaceing heating element in Asko D1996
Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Both terminals are secured in place with a lock nut. You can use a crescent wrench or a pair of pliers to losen, and then remove each lock nut. Reach into the dishwasher and lift the element out. Discard it. Situate your new heating element in place of the old one. Slip the terminals through the holes in the base of the dishwasher. Replace each of the lock nuts. Use a crescent wrench or a pair of pliers to tighten them in place. Now reattach each of the wires - remember, you labeled them earlier so you'd know which one leads to which terminal. Put the lower kickplate panel back in place. If you removed a heating element cover, replace it now. Replace the lower dishrack, and close the dishwasher door. Restore power to your dishwasher.
Posted on Jan 22, 2011
Asko d1996 circulating pump
A new circulating pump will be available on line from this site
Asko Dishwasher Circulation Pump 8801312
Aug 29, 2014 | Washing Machines
Rinse aid dispenser not working
You have to take apart the whole door panel to see what the problem is,.
Jun 07, 2013 | Asko Dishwashers
Asko D1996. 2 wet spots on floor in front of unit, (~1/2 cup). It continued to run, but the inside bottom of the machine was dirty, as though it slowly drained its wash water. Dishes mostly clean..
If you can open the panel and allow the panel to dried then tested to confirm before the panel is removed.
Use a hair dryer or a good air jet to remove all moisture from the panel and see if this works.
Oct 27, 2011 | Asko D1776 Stainless Steel Built-in...
Apr 14, 2010 | Asko D1996SS Built-in Dishwasher
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
My ASKO D1996 Dishwasher will not turn on, checked the power and it is running, but no lights or anything turns on. I don't have the water connected to the machine, could this be the problem?
NO, you should get light actions even if the water was not connected. this is a main control issue. there is a control board kit available for your unit. you will need to replace this damaged control in this case. the logic sector is damaged.
Jul 19, 2009 | Dishwashers
Possible causes
3. Fuse has blown.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
Feb 28, 2008 | Asko D1776 Stainless Steel Built-in...
Asko TouchProof D3232XL Stainless Steel Built-in Dishwasher Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
