Question about Reddy Heater-30-55,000 BTU Variable
I have a reddy 55,000 btu kerosene heater i bought used and it worked fine the first day it stayed on as long as i wanted it to now it only runs for like a minute and i don't know why it has plent of kerosene in it to please help thanks
  • 3 more comments
  • Jeffrey Turcotte
    Jeffrey Turcotte Mar 24, 2011
    Hi, the flame sensor is not working. Try cleaning it with some steel wool.
  • tremaynerees Mar 24, 2011
    where is that located at i mean its heatin up it just dont stay lit for long like it use to
  • Jeffrey Turcotte
    It's usually a cylinder that sits in front of the flame. Let me look it up for that model.
    thanks alot
  • Jeffrey Turcotte
    Sorry, I think your unit uses a small photo cell that looks at the flame from the back. Check to make sure it isn't blocked. You might need a new one.
    Brigadier General:
  • 4,736 Answers
It could be a pressure problem, old fuel, clogged nozzle, etc. If you can furnish me with the correct model number, I will be able to help you further. Reply by using the Leave a Comment link.
Thanks
Posted on Mar 24, 2011
Runs than shuts off after a few seconds
Is this a propane or kerosene heater? If it is kerosene, check your fuel, clean your tank and start with fresh fuel. Check your fuel filter/air filters at the back of air pump. Make sure your ignition system is working.
Dec 01, 2010 | Reddy Heater-30-55,000 BTU Variable
My 55,000 BTU Reddy Heater is filled with kerosene and plugged in for the first time this heating season but will not turn on. The on / off sywitch shows current. I turned it off and waited 10 seconds...
Does this unit have a t-stat in it??? They can go bad when just sitting around....otherwise I would look for a broken or chewed wire....may have got a mouse in there somewhere...
Use an electric meter and follow the electric and see where it stops...
Here are a couple of tips that I wrote that tell you how totroubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 25, 2010 | Reddy Heater-30-55,000 BTU Variable
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a portable forced air heater Model R55A heater size 55,000/Hr can I use diesel fuel instead of kerosene?
You can, but prolonged use of diesel fuel will burn out the cone faster. Too hot. And it stinks alot worse than kerosene.
Oct 14, 2009 | Reddy Heater-30-55,000 BTU Variable
Types of fuels
YOU COULD RUN ON # 2 HEATING OIL BUT WOULD NOT RECOMMEND DIRTY AND MORE LIKELY TO GUM ALSO DOES NOT GENERATE SAME BTU PER GAL I WOULD STICK WITH KERO
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater won't stay on
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Nov 19, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
218 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
